from what i understand, someone had an accident into him, and as he was putting the car onto a towtruck, someone hit the car again
yeah thats what happened. parked car in no standing zone, car into of me hit the brakes to avoid it, i hit brakes and stopped and the car behind me locked up and slid into me pushing mee foreward. then when the other cars had left and the tow truck came for me, the towy backed up and as he was about to put the tray down another car ran into it at speed and rammed it under the back of the tow truck :thumbsup:
Shit it's going to be a tricky one for insurance.... who pays for what?!
Lucky both cars that hit me had insurance. the frist guys insurance told me they will try to asess how much damage was accured in the first accident, dunno how they'll work that one out, the cars about a foot shorter now.
sorry dude. i know where a blue s13 silvia is if your interested. ca18e/auto has hail damage but for $1100 could make it into something good, has hicas, sunroof, original mags, same colour as mine. hail damage has effected bonnet boot, top of doors. windscreen. but for track car, cheap cheap body. i almost bought it last week, just to put back on ebay and make a few hundred easy dollars.
gonna wait abit and see if i buy back the wreck first. thanks anyway :)
  • Replies 185
Posted Images
Damn I didn't get here in time :( This will be the first DECA I haven't raced in since I first started :wub:
Oh well I'll still come up. I can Marshall on the mini wang if you guys like?
Bad luck mate, what broke?
I will take you off the list and bring on the first reserve. All pull outs will be refunded after the event.
Not sure mate. Front of the head is knocking; i'm thinking a lifter, valve spring seat, etc.
Going to also pull the oil restrictors out the block. The combination of N1 pump and 1.5mm oil restrictors is not working for my engine, the head has always been noisy on idle, since the rebuild. Also going to do a couple of other small tweaks; i'm useless, just can't help myself :banana:.
Its not the VCT clicking...?
RB20's don't have that do they? :D
Hey Leon.
I went moto riding with Andy on the weekend. He told me you bought his car. Are you bringing that to DECA? See if it can handle more than 1 run?
Going to also pull the oil restrictors out the block. The combination of N1 pump and 1.5mm oil restrictors is not working for my engine, the head has always been noisy on idle, since the rebuild. Also going to do a couple of other small tweaks; i'm useless, just can't help myself :P .
damm i haven't seen a rb25 do a lifter or a valve spring seat. Does it still run smooth ? i.e not misfire or huge unusual lump in the engine cycle.
RB20's don't have that do they? :)
is this how you humour yourself ? rb20's don't have vct, or a bullshit oil feed going to the front of the head
oh and for the rb20 bashers, look at who won deca last time.
RB20's eat dick russell you know that :P
Campbell
When your RB25 pos beats me then I'll listen to what you have to say :) Actually if it ever makes it to Deca I will!
"cough" the results where rigged "cough"
hahahaha gazelle d's breath smells like Russell's dick
and Dean i'll sort you out on the way to superlap woot woot superlap
Campbell
Not a problem. List updated. Tim or campbell make youselves useful and tell Dean he is in for deca and to pay up :blink: cheers.
Told him on the weekend but will remind him today as we just got back from Superlap last night
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
