i didn't check out your new tyre's last time, but atleast you had grip unlike last aug.
You have a better memory than me...? Did I burn the semis then?
be careful with KU-36's in the wet.
I don't understand why people say that ku36's aren't good in the wet??? They are soft street tyres!!! Not semi slicks like people keep saying.
The tread pattern has more than enough for water dispersement.
  • Replies 185
Posted Images
i dont find them very good in the wet, but i think i only say that is because i used to have very good street tyres and went to these that are good in the dry but are no where near as good as my old tyres in the wet. not that ive lost control or anything with them in the wet but i feel that they are a bit skittish and unpredictable in the wet compared to my old ones. (old tyres were michelin pilot sports)
This has been my experience too. I tested them the first time it heavily rained after fitting them and they pulled up as quick, if not quicker than my original tyres (which still had tread left). Not saying they're awesome wet weather tyres, but they're certainly not terrible.
But good news anyway, bom.gov.au is now saying no rain for Saturday.
I'm surprised to at what people don't think is any good in the wet. A good set of semis is far better in the wet than plain old road tyres. I found my old A048s were far better than road tyres at Winton in the wet. I don't put the ku36s in that class but I would expect them to be more than capable in the wet.
Can't wait for sat!
Can't wait for sat!
Semis are definantly better in the wet than streets once they warm up. When they are cold they are terrible. A050s are the only exception as they arent too bad cold... thats why they cost the most i guess.
I want to enter this next round, what cams licence do i need to get to go in this as well as for drift days?
CAMS is $100/12 months and you must have club membership with a CAMS affiliated club (I see you have SAU Vic members, so no problem).
Link - http://cams.com.au/en/Development/Get%20In...ce%20Types.aspx
You need to get the Level 2 Speed License
AASA is $50/12 months
Link - http://australianautosportalliance.com/aas...9&Itemid=45
You need the Club Racing License
If you are able to arrange one before the day of the event, it makes your morning and my morning much easier.
Id do it ASAP, and make sure you tell them you need it by the competition date.
Otherwise, you can fill out a form and pay on the morning of the event.
Regarding which license to get - its completely up to you and which events you plan on doing in the future.
If you have any intention of going to Sandown or Phillip Island, they will only accept CAMS.
If you are just planning on doing our DECA's and maybe a Winton, get AASA.
Your call :)
Hope this helps
interesting to read that slicks can be good in wet. but yeh i don't know how you guys get enough heat into them for a deca day. with the spread out driving format i'm not going to consider it.
i hear that often. you basicly had no traction on the skidpan in a straight line. i found it quite interesting at the time, and you were complaining about tyres at the mexican joint. my mate Karlos (the blue VN guy) and i were sitting at the table near you
having a chat to a supra driver a status tuning today he said someone rolled there car at deca last weekend on the back track they were going pretty hard and come off and over it went..got a nistune for the stagea today 164 kw and a bit more response so see how it goes on the skid pan
Ouch...did he say if it was a 4WD? You can roll a car almost anywhere as long as you have something to tip the centre of gravity :)
That's it. I know a number of cars have had big accidents out on the back track. Years ago (prob '99ish) I saw a very high powered Datto 120y hit the tree, going clockwise towards the 2nd hill, coming out of the lh sweeper. Destroyed it. Earlier that day his daughter lost it into the first turn, went through the fence into the paddock where the houses are now. That was a sprintrun by the Shep car club. I was running in my red mazda (in my avatar)
Thanks to everyone pointing me in the direction of tyres. Kumho has no 225-45-17s in stock in nsw or vic. Luckily Essendon tyre power had a very good set of second hand 225s which suit me perfect! 225s front, 255s rear. Thanks again guys! Can't wait for Saturday!
Was your Series 4 down at Centreline in the past couple of weeks? They had one down there that looks just like the one in your avatar.
That's the series 1 in his avatar.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
