IMHO the 3071 w genuine housing is definately the best turbo choice for an RB25 in the current climate (2835 being number 1 but cost prohibitive these days)
BUT..........
if i had my time again i would be going a twin scroll 3076 with a 6 boost manifold and GTR plenum
I thought the consensus from discopotato was that the twin scroll didnt have a big effect on 6 cylinder engines, more 4 cylinders.
The 6 boost manifold is probably a bit separate as it would help all of the turbos we are discussing.
If you plot your current turbo against the 3076 you have more area under the curve.
  • Replies 139
hence the twin scrol idea.... i thought it would get me a little more under the curve but not much, hence why i wouldn't change over to that setup, it's just what i'd look at doing if i had my time again :P
actually if i had my time again, i'd probably have just done an LS3 conversion
yeah the reason disco said twin scroll is more suited for 4 cyl is because the firing order and the engine is optimized to suit the firing order
like the 4g63 and sr20 are more suited for twin scroll as the firing order matches the manifold split setup
i wonder how complicated a properly twin scroll manifold on a rb20/25/26/30 footprint would look
and perform with a properl twin scroll manifold with the correct firing order match and turbo to suit
Twin turbo does not follow the firing order (in terms of GTR), where twin scroll is meant to given the parted collector/rear housing
difference - who knows, maybe a few hundred RPM?
You aren't talking 1000's of RPM of response either way.
I got 254kw at 3200rpm with r33 gcg high flow turbo. Im very happy with the response and power i have with this turbo. I only paid $850 for gcg from SAU forums and sold my stock turbo for $300. So only cost me $550. i still retain factory air box and car looks very stealth. Best bang for buck turbo.
I know of people on this forum who have run 12.3s quarters with this power on semi slick street tyres.
Invest in some mickey thompson full race slicks on 15inch chaser rims and a jim berry full monty race clutch and you will run 11s with around 250kw.
Its not always about all out power. Many other factors to consider...
hey mate 254 RWKW yeh? if so thats not bad at all for a highflow especially for that price!, what injectors do you use? also how much did you get charged for installing the new highflow turbo, did it need anything different to fit it or did it slot straight in like before?
sorry for the hundreds of questions.. but with my wage, id much rather 254rwkw for $850 or $550, as opposed to 300rwkw for $3000
cheers.
I'm not sure what you mean by that? The front 3 and rear 3 alternate so with twins each manifold collects the same as a properly designed twin scroll manifold...
cheers.
I sourced most of my parts from SAU second hand from good honest people, thats why i love this site..spread the love.
Paid $850 for GCG high flow only 2 years old checked by gcg , sold my stocker for $300 so cost me $550 and installed it my self, piss easy took about 5 hours and everything bolted straight back on. True direct bolton , nothing to change. If i can do it , any one can.
Apexi power fc=$950 second hand SAU
Nismo 550injec=$600 second hand SAU( need injectors to max out turbo potential)
Bosch 040 in tank fuel pump=$50 second hand SAU(needed to meet fuel demands)
Splitfire coils=$450 second hand SAU(needed to run bigger gap on my plugs, went from .7 to 1.1 coppers when i upgraded coils.
JJR return flow coooler=$450 new
3 inch exhaust turbo back full stainless=$650 wreckers
Greddy profec b EBC
Run stock air box.
Tune=$750 unigroup engineering
My set up is begging for a garrett gt3071 or 76r bolton replacement and retune but this exercise will cost me between $2500 to $3000 , to gain an extra 30kw atw on my current set up. The only way i would justify this would be to take a ride in a gtst making 280kw + . If blown away by the difference then i would do it.
For now im at peace with what i have.
Hope i helped.
No offense - do you know how to read a dyno sheet?
You have 254rwkw @ 6750rpm. Not 3200rpm.
You have ~135rwkw @ 3200rpm
You also have boost control issues.
I stand corrected
Thankyou for teaching me to read a dyno, thats why i love this site, you never stop learning
What i should have said is that you will have full boost 16 to 18psi by around 3200rpm with this turbo
Thanks.
Cool, yeah I was scratching my head but didnt have the knowledge to go against the president haha
So it seems a big waste to go to all the effort of twin scroll on an RB20/25 when an RB26 with twin turbos already has everything done from the factory.
So is this the major reason that twin turbos on an RB26 will have more low down power/torque then the equivalent sized single turbo conversion?
where you live?
i'm happy to er... "help" :(
Hey guys, similar question i thought you may be able to answer:
One turbo, running in a 220kw tune (injector and afm limited), vs the same setup, but with injectors and obviously a bit more boost (profec b) for 270kw.
Obviously off boost performance is identical, and full boost performance is waaay better, but what's the "in between" area like?
I used to have an MR2 years ago, and when boost was turned down, it was linear and boring, and with boost up, it was epic fun, but felt like it had a shitload more midrange. So i'm wondering, when i get injectors and a tune, is it likely to be a lot more midrange, or just top end stuff, it's a really laggy turbo i can't afford to replace yet (KKR560). I'd imagine it would seem more "responsive" as the wastegate would stay shut for longer before hitting full boost?
I'm just poor at the moment, but think i can afford injectors and a tune by the end of the year, as a present to myself, and want to make sure that the performance jump is as epic as i am expecting it to be :( Gavin Woods will be doing the tune, as he's a champion :(
Midrange will jump mainly but you will still get a nice top end bump.
Midrange is where its at anyway, how often do you hit 7000 revs?
Equivalent sized SINGLE ENTRY single turbo, yes - and no its not a waste on a 20/25 as you only have to buy one turbo etc... imho. You have far more choice with single turbos, less plumbing, etc. Try working on a Skyline with a big single versus low mount twins haha.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
