  • Replies 136
Yeah I'd be interested to see how cutting the turbos off and effectively laming a gtr produces...188awkw? I call bullshit. My stock gtr makes 190. Besides, the engines not designed to run efficiently as na. Grow up kid...just like the rest of us had to before we got to drive the cars we wan. We respect them, not torture them.
And badges are the only way to identify a gtr? Puhlease. It's a different body shape.
Probably doesn't even have one if he doesn't know the difference
sorry 256 horse power and its amazing the things you can manage to do when you not on your ass dribbling shit on other peoples posts, and in a shed working on your car and i managed to find the engine 90% done so i didn't need to build it thanks
So you're saying you got ~190 aw kw from an NA RB26? Wow, I shouldn't have bothered adding a Power FC, intercooler, boost controller, fuel pump and tuning to my RB25DET NEO, I should have just dropped in an NA RB26!
Got some pictures of the engine or dyno sheets?
FYI the Autech RB26 NA -
Power: 220ps (164kw) at 6600rpm
Torque: 25.0kg/m (245Nm) at 5200rpm
Bore x stroke: 86x73.7mm
Displacement: 2568cc
Compression ratio: 10.5:1
By the way I'd love to know what supporting mods you have on your car for this power...
Supporting mods are listed below:
Turbo whistler
Intercooler style air filter
Shopping list + custom vinyl (Yes it's a R33, but you get the idea :))
the rb26 is missing the top end
hmm 90% done and no top end. I can see the logic in that, plus no building either so the top end magically found it's way from where ever it was to your engine and mated itself perfectly to your bottom end, AWESOME! I need me one of those magic engines. What exhaust manifold did you use? or did you use the stock one with the BOV Coke can mod to cover up the holes
It's also amazing the amount of shit people can talk in their own posts on their own FAIL thread!
Hairdryer engine mod next, you know, not just for the lols but for the wicked acceleration you'll get from all the electric boost!
thanks for all your help the car is up and running dynoed it today with 256kw na power to all 4, car is fully debadged for all you guys that "dont want your reputation crumbled" for all those people that i'll race won't know its a gtr
cheers
WAHAHAHAHAHAHAHAHAHA! Jack The Ripper couldn't give me a bigger smile than what I'm wearing right now. That was too funny!
They won't know it's a GTR because they usually expect the GTR to win. When you have all the lag of a turbo without the turbo, you can't expect much.
i have a sneaking suspicion that y'all niggaz got troll'd
LOL
Possibility is on the cards, but it's still funny...
LOL so about 256kw at the fly, you should consider a job in R&D for a world class engine manufacturer. Hell, you've done better than BMW did with their 3.2 litre M3 engine. And all within the confines of your shed. How's that compression ratio by the way? lol. Please don't have children, we don't need more of you.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
