what's a valet boot locking switch?
weird thing my 32 does is the climate control screen comes on and off randomly (mostly off now)...
valet boot locking switch is on the inside of the boot lock, when its on you cant pop the boot from the cabin. but with that your spose to have seperate keys for the boot and ignition but mine are the same so whats the point there? :)
also, my screen goes loco sometimes too.. instead of going off, every LCD part goes ON, sometimes only parts go on. It's a loose connection in there but I managed to score another climate control box for 5$ :)
Shaun
  • Replies 121
1. Every time I switch the ignition off the engine keeps on running for anywhere between 30sec & 2minutes. "After a few months of driving took it for a service & they fixed it...(nice guys didn't even charge me) they said it was something called a turbo timer & just ripped it out :)
2. Occassionally after a few drinks, I use to jump into the car & notice the dash & steering wheel are gone & moved over to the (as we know it) passenger side. I now realised that I was in the 56 thunderbird left hand drive :)
3. Dunno bout you guys, but does your fuel cap swap sides. Sometimes I go to fill up & could have sworn black & blue the cap was on my drivers side :confused:
I believe the headunit turning off during gear changes is probably a ground issue (as said).
On my car there is a ground wire connected to a bolt at the top of the gearbox near the shifter. If this has at some stage wrapped around the gearstick underneath the gear-boot it may cause problems if that ground was used for something.
Let me see what the weird thing about my car.
My driver's side electric window switch is really sensitive. One small touch and it will wine down, even going over bumpy road sometime.
My climate control off button is jammed for some reason and now I can't switch off my climate control.
And now my antenna is stuff too. It will go up but wouldn't retract automatically, have to get out and shove it back down.
i have a funny button in my ash tray and when i push it, the car goes much faster :)
but the weird thing with my car, is the dimmer switch for the dash, that was put in for compliance is in the most stupid position its so easy to bump...
well my car doesnt have that problem, in fact, it doesnt have a dimmer switch at all lol
My climate control makes a knocking sound when i turn the car on does about 8 or so times also does it when the aircon changes fan speed.
My seat belt makes a clicking noise which I also now can rarely hear after exhuast install. :bonk:
Yeah I noticed when I pulled the climate controll out in my 34 that when I put it back and switch the car on for the first time after that it makes a horrible knocking too. I think it's some type of system reset thing, maybe a system check. I'm an electronic engineer and it puzzeled me :wassup:
hmm where to start!!!
I get a click click noise when i start moving, the same noise but much worse at high rpm/high boost, sounds like a driveline noise.
where do i start with wiring! theres heaps of it! sunroof closes to about 3" opening then you have to take your hand off and press switch again.
aircon doesn't work cos some gimp took it out!
main concern is my battery can go flat very quickly, its only a piss weak lil thing, but like when i was installing a cd player and testing stuff out it went flat.
i left it for 2 weeks and it wouldn't start, charged it started it, moved it around. i stuck my head in and could tell just by looking that it was flat (fuel guage not reading, interior light not on) my skyline has sat there since july and i start that every so often and she first first time
Has two annoying things as well.
One is a stupid noise it makes under no or low engine load ever since I had the E boost fitted. (really annoys the wife)
Listen to it here
http://www.cwp.id.au/skylinenoise.mpg (1.47mb)
The other tink is it seems to loose power for a sec at around 5000rpm when the boost is on or over about .7 bar (I suspect that this wont be an issue when the new computer is fitted)
how did u get compliance widout dimmer switch...
Probably the same way mine did... I have searched all over and I would bet my leftie that my car hasn't got one fitted.
The only wierd thing about my 'line is that it makes most falcodore drivers think that they are Peter Brock or Dick Johnson.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
