  • Replies 121
my car makes a whistle noise at about 3500 rpm and a bove and when i take my foot of the gas it makes kind of a sneezing noise the higher i change gears the louder it is.
Your running a pod filter arnt ya
my turbo timer won't let me lock the car whilst it's counting down...kinda making it obsolete. I've found out that they're a little useless, as my EGT will give me a better indication of when to turn the engine off. My turbo timer is mainly used for it's other functions now (HKS Type-1).
Found another issue - I can't adjust the height of my steering wheel. The locking thing which you move down to move the steering column up and down is stuck. I might have to use some ingenius ways to loosen it...
Auto right?
Both my jap cars have done this (supra and skyline). I think its just so you know your in reverse, like a truck reverse alarm :D
I think its factory in autos.
This confuses me rather than annoys, but :
Every Time I put the 'line into reverse, there is a loud 'beeping' coming from the dash area.
At first, i thought it was a parking radar or similar, but no-matter how close I reverse to a wall, the beeping is constant.
(This is only audible inside the car, but is at the same rate as a truck reverse beeping)
Grr!!!
i i go 2 drive my car, with in 5 minutes of it first running, when you put the clutch in the revs go up 2 1500
goes away as soon as its warm,
This also happens in my S13 SR20det Silvia when cold. I don't think it's a problem, it's normal when the car is cold.
I know you meant this as a joke, but a friend of a friend (I have met him, he's not one of thise non-existant friend of a friends) bought a SW20 MR2 off a Japanese lady who was sent the car by her son, and got $2 grand off the price cause she thought the blow off valve sound meant that something was wrong with the gearbox!
Hmm, it actually seems kinda harsh now, ripping off someone who doesn't know about cars... :) O well, seemed funny at the time :(
Auto right?
Both my jap cars have done this (supra and skyline). I think its just so you know your in reverse, like a truck reverse alarm :(
mine has the same thing but the japanese owner has pulled out the plug to the little grey box under the dash
EDIT - it still makes it it was the speed warning that was unpluged along with the headlight buzzer
My GTR 32 does the climate control bit and now the front wheel torque guage on dash moves as if appliying torque to front wheels, but with no hard excelleration, it never used to do this unless it was supposed to when excellerating hard, i have new tyres and profiles are all the same. Has enyone experienced this, it basically follows the tacho??????
  • 1 month later...
Does anybodies AFM to TURBO duct suck closed at resonable boost?
Jees, wouldn't it be a great idea to replace the rubber duct with an alloy one to eliminate any sucking closed....
Well, have I got an deal for you.
Check my sig
i am my cars turbo timer, like a tight arse, i take it easy on the last few kays approaching destination and then before exiting the car i let it idle for 1-2 minutes.
Here in sydney we can get fined for leaving our cars running without owner/passenger in the car, also get fined if we leave cars unlocked while paying for petrol at the counter.
F#!@& talk about revenue making schemes.....
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
