Looking at 225/40's on the front and 235/40's on the rear! Was
thinkin +25 cos wasnt sure how much camber i will need run gunna roll the gaurds though! Gettin +20 on the rear! Would the front tuck in u reckon?
Go the +20 all round.
9.5s are not too wide for the car.
What size tyres are you looking to run on it?
Sorry, if its a GTSt with std guards, even if the insides are rolled then its my experience that sized rim will not have a hope in hell of fitting on an R32 GTSt
At best you will get a 9" +28 or so on the front and a 9.5" + 36 or so on the rear. Even that will fill out the guiards and probably rub depending on ride height and tyres used.
A far better bet for a decent stance is 8.5" +30 fronts and 9" +30 rear. For the size tyre you want to run then they will fit that sized rubber better too.
I have very heavily pumped guards on my car and here is a pic of it with 350/340mm ride height and R34 GTR rims which a 9" + 30 all round They clear nicely with no rubbing. But you are talkign rims that are about 12mm wider and with a further 10mm offset. No way i can see them fitting with std guards!
One of my mates got a 32 gtst aswell hes got 17x9+17 all round with in gaurds taken out and gaurds rolled! So im thinking more along the lines of 18x8.5+17 on the front! And 18x9.5+20 on the rear! Would that work! With 225/40's on the front and 235/40's on the rear!
  • 3 months later...
Hey roy,
what size tyres are u running there?
cheers mick
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
