I have totally redesigned the previous version; creating a new interface which is easier to use, has more precise calculations and new features including 2D modelling of tyres and wheels.
Car Calculator V3.0
Features include:
- Power (kilowatts - horsepower)
- Torque (newton metres - foot pounds)
- Speed (KM/H - MPH)
- Weight (kilograms - pounds)
- Displacement (litres - cubic inch)
- Boost (bar - PSI)
- Distance (kilometres - miles, metres - feet)
- Fly Wheel (factory output to wheel rating, awd-fwd-rwd)
- Speedo (speed adjustment based on tyres size)
- Tyre Diameter (rolling diameter of a tyre and the ability to compare tyres)
- Tyre Stretch (visualisation of tyre stretch based on width, profile and wheel width)
- Wheel (visualisation of a wheel based on size, offset and camber)
- Mileage (L/100KM - MPG)
- Fuel Economy (distance per dollar and visa versa)
- Fuel Consumption (mileage based on tank size and distance)
- 0-100KM/H (estimate based on power and weight)
- 1/4 Mile (estimate based on power and weight)
- Top Speed (estimate based on power and weight)
Feel free to give me feedback and any ideas for future versions.
I also encourage you to share this with your friends on other websites/forums.
Edited by steveP
https://www.sau.com.au/forums/topic/321213-car-calculator-v30/
ok... i saw this post when it was first posted up lastnight... and... i'm really sorry
...but i don't get it... what is it, what's it do and what's it for?
EDIT
i dunno why - but i just got that image in my mind of Homer Simpson's dream invention
HOMER! do you realise that BECAUSE of your invention EVERY american home is going to have at least THREE, or FOUR of this product!!!
...can i see it?
HOMER!!! what do YOU need to see it for? you INVENTED it!!!
hahaha
Edited by Mr Eps
  • 1 month later...
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
