Chris Wilson Posted May 19, 2010 Share Posted May 19, 2010 I am in the UK, so please nothing made only in Oz, no offence Looking for a track day exhaust for an R33 GTS-t on an RB26 engine running 280 degree cams and 2860 -10 turbos, so it's a bit vocal at the top end. Has to be 100% sure of passing all UK track day noise tests, I don't care WHAT it sounds like, it just has to be very quiet and with as little restriction as possible. As an example an HKS Hi Power Silent is FAR FAR too loud, I need something as close to stock noise levels as possible. Thanks. 102 Db static, at about 4000 RPM needed absolute tops. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/ Share on other sites More sharing options...
N1GTR Posted May 19, 2010 Share Posted May 19, 2010 Shame you dont want Oz made, there are at least 2 companies making high flowing exhausts to DB levels (eg custom). You should mention what the DB limit is that you're trying to reach Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243537 Share on other sites More sharing options...
Swiper the Fox Posted May 19, 2010 Share Posted May 19, 2010 (edited) Racepace...hands down, end of story, close and lock please mods. Personally had a drive in a 440+ KW at the treads R33 GTR that sounded and idled like a brand new stocker. I know of one for sale too... Edited May 19, 2010 by Swiper the Fox Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243556 Share on other sites More sharing options...
R31Nismoid Posted May 19, 2010 Share Posted May 19, 2010 So -10's, should be 450rwkw+... you are looking at something 4" at least if not more... oh dear... How far away is 102dB measured? 5m? 15m? Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243567 Share on other sites More sharing options...
Chris Wilson Posted May 19, 2010 Author Share Posted May 19, 2010 I don't want anything bigger than 3 inch, even if kills some power. I need to be practical about this I do mention the desired Db figure in my original post. Details of the noise test are 102 DB at 0.5 metres from the exhaust tail pie, measured at 90 degrees to it, at 4000 RPM. I would consider buying from Oz if the postage wasn't an absolute killer and i was sure the system would meet my needs, so can you let me have a link to these Racepace systems please, and the one for sale? Thanks. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243645 Share on other sites More sharing options...
TiTAN Posted May 19, 2010 Share Posted May 19, 2010 If you cant get something custom made locally 3.5" or 4" (i have been looking for quiet large exhaust systems) you can see if racepace will make up and send you over a system, but all of the jap etc systems i could find had a little hotdog and a canon on the back that does practically nothing to the noise level. 1 Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243648 Share on other sites More sharing options...
TiTAN Posted May 19, 2010 Share Posted May 19, 2010 I don't want anything bigger than 3 inch, even if kills some power. I need to be practical about this I do mention the desired Db figure in my original post. Details of the noise test are 102 DB at 0.5 metres from the exhaust tail pie, measured at 90 degrees to it, at 4000 RPM. I would consider buying from Oz if the postage wasn't an absolute killer and i was sure the system would meet my needs, so can you let me have a link to these Racepace systems please, and the one for sale? Thanks. If you currently have a 3" exhaust system on the car you can fit an off the shelf 3" straight through offset > centre oval muffler (16" deep x 11" wide x 6" high) my exhaust with that muffler on the rear and a hotdog in the middle is 92db @ idle (45 degrees and 50cm from the exhaust tip) and 89db @ 3500rpm. If you want something off the shelf the Kakimoto Regu 06&R has a decent sized mid muffler and a canon on the rear, if that is not quiet enough you can get the rear muffler changed by an exhaust shop to a larger item to take more noise out of it for a relatively small cost. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243668 Share on other sites More sharing options...
R31Nismoid Posted May 19, 2010 Share Posted May 19, 2010 I don't want anything bigger than 3 inch, even if kills some power. Erm 3" and 450rwkw+ worth of turbo do not mix at all well mate. You are going to need 4". Even 3.5" is really asking a lot for that type of setup. Anyway 102dB @ 50cm, 4000rpm = should easily be doable. My Racepace exhaust is 91dB @ 5100rpm - 3.5". This is around 50cm from the exhaust tip as well. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243721 Share on other sites More sharing options...
Ten Four Posted May 19, 2010 Share Posted May 19, 2010 I had a Futjisubo one. I daresay quieter than stock. Was slightly bigger than 3" too. Too bad I sold it and didn't get model =/ It just had rediculously huge end muffler and resonator - so big I couldnt fit a whiteline swaybar cause it was in the way. Just get a local one made up with huge resonators? Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243722 Share on other sites More sharing options...
Chris Wilson Posted May 19, 2010 Author Share Posted May 19, 2010 I hear what you are saying re a locally built one off, but past experience has shown some one ofs fail miserably in the noise department, so many companies are into huge bore systems and massive exhaust tips it's hard to drum into them that I want *QUIET*, modest pipe sizes for ground clearance and still more silencing, and care not a hoot about looks or "that special sound". I just want to tip up at any UK circuit KNOWING it will pass the noise tests, even if it's 70 BHP down on its potential. Thanks. Any contact info for the RacePace system for sale, or RacePace themselves? Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243783 Share on other sites More sharing options...
s2d4 Posted May 19, 2010 Share Posted May 19, 2010 (edited) man, how did you build a track car without using google at some stage of your build? Curtesy of google http://www.racepacemotorsport.com/main.html Pretty sure this is the right one, correct me if i am wrong boys/girls Edited May 19, 2010 by s2d4 Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243789 Share on other sites More sharing options...
bigmikespec Posted May 19, 2010 Share Posted May 19, 2010 Can you go twin 3" tubing all the way? Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243873 Share on other sites More sharing options...
R31Nismoid Posted May 19, 2010 Share Posted May 19, 2010 I hear what you are saying re a locally built one off, but past experience has shown some one ofs fail miserably in the noise department, so many companies are into huge bore systems and massive exhaust tips it's hard to drum into them that I want *QUIET*, modest pipe sizes for ground clearance and still more silencing, and care not a hoot about looks or "that special sound". I just want to tip up at any UK circuit KNOWING it will pass the noise tests, even if it's 70 BHP down on its potential. Thanks. Any contact info for the RacePace system for sale, or RacePace themselves? So simply tell them you want 4" with the two biggest mufflers money can buy? As i said above about the sound requirements - they are realistically NOT that harsh at all. 102dB is pretty lenient mate and gives you serious flexibility to move about. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243931 Share on other sites More sharing options...
mad082 Posted May 19, 2010 Share Posted May 19, 2010 I hear what you are saying re a locally built one off, but past experience has shown some one ofs fail miserably in the noise department, so many companies are into huge bore systems and massive exhaust tips it's hard to drum into them that I want *QUIET*, modest pipe sizes for ground clearance and still more silencing, and care not a hoot about looks or "that special sound". I just want to tip up at any UK circuit KNOWING it will pass the noise tests, even if it's 70 BHP down on its potential. Thanks. Any contact info for the RacePace system for sale, or RacePace themselves? it really comes down to the choice of mufflers. simply make sure it has a big centre resonator and a big oval rear muffler (no cannons). it may be worth looking at a twin system something like a twin 2.5 or 2.75" system may be another option to look at (or even twin 3"), as you will be able to get muffler with good noise attenuation in those sizes. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5243980 Share on other sites More sharing options...
zebra Posted May 20, 2010 Share Posted May 20, 2010 If you dont care about power loss than throw the standard system back on. Might not run very well but it will be quiet Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5244445 Share on other sites More sharing options...
Brandon Posted May 20, 2010 Share Posted May 20, 2010 If you currently have a 3" exhaust system on the car you can fit an off the shelf 3" straight through offset > centre oval muffler (16" deep x 11" wide x 6" high) my exhaust with that muffler on the rear and a hotdog in the middle is 92db @ idle (45 degrees and 50cm from the exhaust tip) and 89db @ 3500rpm.If you want something off the shelf the Kakimoto Regu 06&R has a decent sized mid muffler and a canon on the rear, if that is not quiet enough you can get the rear muffler changed by an exhaust shop to a larger item to take more noise out of it for a relatively small cost. I'm pretty sure this will do the trick if my TI-R blew 92.5dB. They're one of the best sounding, good looking and quietest aftermarket exhaust for sure. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5244529 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 20, 2010 Share Posted May 20, 2010 kaki FTW Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5245329 Share on other sites More sharing options...
eXquiSit Posted June 7, 2011 Share Posted June 7, 2011 does racepace make the mufflers in house? they dont have much info on their mufflers on thier site Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5854056 Share on other sites More sharing options...
R31Nismoid Posted June 7, 2011 Share Posted June 7, 2011 Yes, inhouse. Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5854115 Share on other sites More sharing options...
simpletool Posted June 7, 2011 Share Posted June 7, 2011 (edited) You will need a full twin system. You want the maximum cross-sectional area coupled with sufficient wall surface area to provide sound dampening. A 2 x 2.75" system would suit you well. Cross-sectional area equivalent to 3.8", surface area equivalent to a 2.75" (but doubled obviously, although this cancels out). Ta-da.....custom exhaust twin 2.75" with decent resonator/s and muffler/s. HKS has the N1 full-dual (prob too loud), 2 x 3" apparently. Kakimoto has one in 2 x 2.75" but again too loud (they say 103db with stock turbos!) However you can see the possibilities, the Kakimoto system has minimal resonators and mufflers, so making a quieter custom system would be no issue. Edited June 7, 2011 by simpletool Link to comment https://www.sau.com.au/forums/topic/321355-the-absolute-quietest-r33-gtr-exhaust-available-internationally/#findComment-5854196 Share on other sites More sharing options...
