  • Replies 51
Posted Images
Post edited to remove pointless dribble about nitto's as I failed to notice he is after ghey 19's
Joeyjoejoe: Yes starting to regret the 19's now... bought when car was essentially stock with no major plans for upgrading it... they look the bizz but makes finding tyres (especially affordable tyres) much harder... :blink:
I'm just shocked at how laggy the car is. 5000rpm to get to 18psi? Something is not right there.
Federal SS for all round performance, or KU36s for the dry.
Yes i thought something was wrong from looking at that sheet as well, but couldn't feel it on the road - I tested it on the road this morning - full boost well before 4500rpm so its just obviously either the ramp rate on the dyno or the way the operator put (or didn't put) his foot down!
Just goes to show that dyno charts need to be taken with a grain of salt...
been around for a while now... i run them every now and then in my drift car. with 310 rwkw and aggressive boost and torque curve it doesnt wheel spin in any gear in a straight line... pretty grippy tyre! they also work well from cold and dont require much heat to get them performing.
you cant be serious about the nankangs, they are good for a burnout and thats about it.
ime dead serious. they are great for what they are and the price, they perform good against better branded stuff. i work in a tyre shop and most people cant aford $400 $500 dollar tyres that do no klms.
there after a good alrounder. if it was a track car it would be different.
but ime not saying there good against some of the other stuff.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
