Hey guys I've just got my car tuned its a R33 with the following mods:
RB25 det
HKS 2835 Pro S turbo
Yellow Jacket coil packs
Z32
FMIC
3" TBE
Walbro Fuel Pump
Power FC + boost controll kit
Nismo 740 cc injectors
it was tuned on 16 psi and obtained 300 hp i had a HKS 2530 before for 16 psi and it was making 300 hp? on same dyno....they tuner told me that he couldn't put more timing into it because it just pings so im just wondering what could cause this?
Cheers
Chi
https://www.sau.com.au/forums/topic/324407-low-on-power-after-tune/
Would have thought you would be making more like 260 - 270kw with that setup. Without knowing your tuner or his workshop I would blame him first. He should be able to tell you why he can't get more power i.e. what needs to be done to fix the problem. i do remember a thread by Guilt Toy where he said that the Pfc gives false knock readings but I thought that was at a higher level. Was your car tuned by the local workshop or is the tuner well known and recommended? there is a huge difference between a mechanic who knows how to use a PFC and a top tuner.
It should make more than 300hp on 16psi, I can't think of much other than the tuner being a major point to look at for fault if he couldn't suggest any reason for why he couldn't put timing in - unless it was false knock.
What fuel are you using?
mmm how about cam timing? and TDC would those two things affect the powers? say if the crank wasn't at TDC ? cause i remember when i bought the engine the old owner of it said he changed the timing belt?
the tuner said there was no point running more boost because you can't run more timing.....
im running 98 ron
Cheers
Chi
Edited by Chi100188
Where are you getting it tuned?
If it's at Hyperdrive, keep in mind Andrew's dyno is pretty pessimistic.
James' (Ten Four) 32 GTR made 370 hp on Hyperdrive's, then 400 on x-speed's.
Similar to me, my x-trail made 225 at Hyperdrive, then 259 at X-speed!
Your not making much power cos that turbo isn't really in its efficiency range at 16psi on a 2.5L.
What does your turbo's intake look like? try to fish some cold air from somewhere, then he should be able to add more timing!
How many kms does the 25 have on it?
[edit] cam timing should be ok, if you're making 300hp, then it's obviously not out that much!
Edited by turbo x-trail
Yes it is way too low. 300hp from a HKS 2835 Pro S and wont take any more boost than 16psi. Something is definitely wrong.
I am guessing its not a fuel issue because your tuner would surely have mentioned if that was it. Now just need to try and rule out different issues one by one. Sounds like something to do with spark, whether it be coil packs, leads or plugs. Maybe heat i suppose.
its not the dyno, as the results i'm comparing are from the same dyno.
Nothing wrong with the turbo intake, i am running the full FULL HKS 2835 pro s kit which had made 320rwhp @ 16psi on a very tied rb25 (150,000km+) before i bought it.
XRATED: it has nothing to do with a dyno sheet the fact of the matter the car should be able to run more boost but i can't because i can't run enough timing.
What i think is wrong is that the cam gears are not setup correctly. I think it may be a tooth out or something.
When i get the chance im going to rip off the cam covers and set the crack to TDC and make sure the cams are line up correctly
define "pings"
does he mean the engine check light comes on?
or
does he mean the engine is detonating - audible by knock headphones?
also
when he said he cant get anymore did he just leave it at?
why leave it for you to play "debug the problem" he is the mechanic, not you
it makes no sense. surely basics check would prevail here
air
fuel
spark
make power, so check those. is the timing even correct (you mention you think the cam is off) - was this checked before anything (ie before even base tune)
What I've found that low power out put generally associated to the manner of how car owners wanted to modify their cars we well as the government regulations that every one have to obey.
Performance of a turbo mainly consist of: Flow capacity.
The more cool air you can get in, and more hot air to get out the better the performance.
I think you've got a exhaust related restriction as hot air can not be dispatched fast enough so it stays in your combustion chamber causing detonations. (cat restriction?)
Install a 3inch metal intake pipe with a good pod filter and a 3inch turbo back exhaust with no cat. Assume your engine condition is good enough with a reasonable tune and good fuel you will get the expected power level.
On a skyline? That is already cop bait? And risk a massive fine?
Not sure that's very good advice mate...
A decent metal highflow cat can provide almost no restriction, the good quality ones are very good these days.
Plus they double as a muffler/resonator, negating the need for an extra muffler.
Just a thought but if you have a dyno graph then the more experienced guys will be able to comment more on what that is saying. Does the power delivery feel any different to before? The same peak power doesn't mean the low-midrange is the same as before.
As mentioned if you can't make more boost then look at flow/restriction issues. Do you still have the rubber intake pipe from AFM to Turbo? Have vacuum leaks been checked for, eg. hose clamps, split pipes, BOV etc? If you are making similar power then and now and all you changed was the turbo maybe something has been wrong or at it's limit since before and you're only now finding out as you can ask more of it.
Good Luck with it
Edited by Fry_33
Paulr33: The ping that the tuner was experiencing was detonation, the tuner couldn't give me a exact solution to the problem he just suggested a heap of stuff that could cause the low power levels...but i suspected it was the cam timing Ill get that checkd out once i finish my exams.
Hypergear: I've got the metal intake from HKS thats included into the 2835 Pro S, attatched to that is a Apexi pod filter, and the exhaust is a 3inch turbo back with no mufflers or cat....
FryR33: the dyno sheet is quiet consistent with no dips in the power....the car pulls hard delivery of power is about the same.
Cheers
Chi
Very unlikely your cam belt has jumped a tooth while your turbo was being swapped and you would know all about it. If you haven't got a decent tuner in Perth ( have you asked around?) plan your next holiday in a city where there is one.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
