as ethanol burns colder than pulp, e85 has differing spark plug requirements, so i figured we need a dedicated thread.
this thread is to list what you are using and how it performs.
just copy and paste this:
[b]CAR:[/b]
[b]POWER:[/b]
[b]TYPE OF ETHANOL:[/b]
[b]PLUG:[/b]
[b]GAP:[/b]
[b]COLD START:[/b]
[b]HOT:[/b]
https://www.sau.com.au/forums/topic/325835-the-e85-sparkplug-thread/
ok, i'll get the ball rolling :rolleyes:
CAR: R33 (RB25DET)
POWER: 323rwkw
TYPE OF ETHANOL: Powerplus E85 (made by manildra, from wheatgrain)
PLUG: BCPR7ES
GAP: 0.9
COLD START: horrible, 10 odd cranks in winter
HOT: perfect performance once warmed up
i'm thinking of trying 5's but i would like to see some people's results with cold start on 6's first
With all due respect, there is no one correct plug for any engine or power. The only correct way to determine what is the best plug for your application is to start with one, run it for 5000 and pull it out to see what she looks like. It is a good idea to see what others are running, though, so you know roughly where to start from. But where hp vs heat range is concerned, due to the colder burn of the ethanol, you'd be able to go back to a factory recommended heat range and work it from there.
  • Like 1
Yeah, I realise that but I thought having a reference might be a good idea for the future.
The other spark plug thread has determined a few fail safe options over the time it has been running And I am hoping for a similar result here :P
I might go for 6's @ 1.1 next time and see how I go...
CAR: M35 Stagea
POWER: 250awkw
PLUG: Denso IKH22
GAP: 1.1
COLD START: Woeful, I have to add 10% unleaded this time of year to get it to fire. Started this morning at 3 degrees with little issue.
HOT: Perfect.
From my experience ethanol burns hotter and faster when under high boost pressures, a colder plug will be fine. I doubt I will be changing plugs just to get the engine to start better.
Ethanol doesn't evaporate below 15 degrees which is why we have issues, its the petrol mixed in that fires for the first few rotations.
Yeah... This is the reason we don't run e100 afaik
cold start doesn't really bother me too much, it's annoying when I am dailying it, but the ke70 should be finished pretty soon.... But I'll bet dollars to dimes I'll have that thing turboed and on the juice within 6 months anyway :P
for the guys having cold start issues, add a massive amount of fuel, like 50% and take timing back to 0 or 5 degrees. it was something said by a tuner from the states, doesnt seem to have cold start issues, even below 0*c.
There are a few drawbacks I see with that...
If you flood the bore with liquid ethanol it will run down past the rings into the oil and help to break it down.
It is still only the petrol firing, if you ran e100 it still wouldn't want to start well, also with below zero temps.
It would require an arftermarket ecu for those that just run larger injectors or higher fuel rail pressures.
I would have to give up the knock signal on my Emanage in order to wire in the temp signal, then I would have to get a cold retune.
I want to fit a small (say one litre) petrol canister in the engine bay, probably in 3 inch stainless pipe. I have the original fuel pump to slide in the pipe and one of the stock 370cc injectors will install nicely into the manifold. Power these from a simple push button on the dash and you're set. I have seen guys in the US running simpler systems they work very well and save wasting ethanol at startup
yeah just had a quick look over what i thought i read ages ago. seems its only good down to 5-10 degrees C, below 5 it doesnt work. i was confusing it with another one that cold started fine in freezing weather, but not on E85
I think e85 cold starting will be an issue for those with lower compression more so than cold plugs, my VQ25det only runs 8.5:1 compared to 9:1 for the stock RB's. I need boost at startup.
I would really like to see somebody build an ethanol specific high compression engine with high boost, wish I had the funds to build one myself. Perhaps one day... if I keep pushing this one... :down:
did you run that gap on pulp?
No, it was .8 from memory.
One of my friends has a 9.5:1 CR (RB25/30) and his is a pig to start aswell.
i would have thought to achieve better cold start you'd want to lean it off a fair bit.
how many tuners spend enough time on the cold start map anyway... the answer is not enough.
+1
Spark plug is going to have f**k all effect on cold start - unless it's fouled of course
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
