Hi all.
I'm brand new to turbo cars, never driven one before, so got a question to ask the experts in here. I'm looking to get a R32/R33 gtst and just test-driven a 93 R33 gtst. It seems to me that the car is pretty draggy in 1st gear and things only started to pick up in 2nd. I don't know if it's me or the car cause I didn't go past the 3500 mark in 1st (I never like to push someone else's car too hard), though I did feel the boost kicking in at 4000.
So just like to ask all here if it's normal for turbo cars to feel a little draggy before the 4000 mark and if this happens to N/A versions.
Thanks all!
https://www.sau.com.au/forums/topic/326515-question-about-boost-cars/
  • Replies 73
stock turbo supposed to be spooling from 2500rpm... 4000rpm sounds a bit late. that's the downside of some modified ones where the bigger aftermarket turbo don't start spooling till later, it may give higher output but only at top end rpm for drag racing strips, but will go like an old dog on start and go traffic on the street.
if any dropkick gets in a car I've got for sale and starts taking it to 5500-6000rpm constantly the only thing he can expect is to be left by the curbside with a black eye.
as said before, stock turbos will give you a noticeable increase in induction by 2500 RPM ("start spooling" in layman's terms) and should reach peak in the high 4000 RPM area ("full boost" in layman's terms). If it's not doing this, then it's either modified with a larger turbo, got an aftermarket boost controller, or sporting a boost leak somewhere that's preventing the turbo functioning optimally.
+1
prob best description there for your answer mate! :blush:
a bog stock GTST is fairly nimble in terms of aggressive power and "woosh"
that is, from factory, its setup to drive very normal like and give even power increase
so you wont feel it magically "come on boost" or "wheelspin" instantly like some would expect
its only when you tune the stock ecu, modify it, increase boost and un-restrict the motor, that it behaves like that
Thanks guys! Very informative. Maybe I'll try to push it a little more for the next ones, but with the seller being comfy with it first, of course. I didn't ask the seller if everything's stock or not. But i guess a leak might be the most possible reason cause the car's really feeling draggy at 1st gear, feels much worse than my N/A MR2. 1500 - 3000 feels almost the same.
Thanks all once again!!
Give it a poke.
My r33 is essentially stock and doesn't start pulling really hard until 3500+rpm.
While you would never flog a car during a test drive, you would want to hold the wellie against the fire wall once or twice to make sure the car revs and pulls cleanly through the entire rev range. To not do would be silly.
Right.... point taken. Thanks.
Give it a poke.
Also if you're afraid to push it, after you have taken the car for a drive to see if everything is in order, get the owner to take you for a drive and tell him you want to feel full boost.
Yep, this is what I do.
I drive it nice and easy, feel the gearbox, the steering, listen for noises etc. Then I ask the owner to "show me what its got", usually gives a good idea what sort life its had with the previous owner too.
Considering you quoted the same rpm range as I did in my previous post on this thread, I'm hoping that your post was not partially directed at me. At no point did I tell the OP to thrash the living crap out of a car he is inspecting, but rather to at some stage or another during the test drive to push it past his 3000rpm he mentioned.
Of course, if it wasn't partially directed at me, good response.
What I like to do is to ask the owner to drive the car "Hard" so I can get a good feel for it even if it's in the passenger seat. I think it's rude to thrash someone else's car especially if you don't even know that person but if you are going to spend the money to buy the car you want to make sure the engine is still in good nick and there is no problems at high revs.
Lolol I thrashed some curries 300zx on a test drive with jiz boy (think I told you a out it shan). I'm talking bouncing off limiter and taking a corner sideways. All he said nervously was "I have never driven my car like this" twas hilarious :D
Lolol I thrashed some curries 300zx on a test drive with jiz boy (think I told you a out it shan). I'm talking bouncing off limiter and taking a corner sideways. All he said nervously was "I have never driven my car like this" twas hilarious :bunny:
Haha good times bro! His face was priceless :)
That ZX actually pulled hard though. I think we were both surprised.
Hey LNah - I recognise your username from the MR2 forums. Don't tell them that you're going from an MR2 to a Skyline or you'll cop shit ;)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
