Hey guys,
I have been looking for front camber adjustment for my R32 Gts-t. I have a whiteline offset bush set sitting at home ready to be installed but having doubts regarding the reliability/wear of the items (I don't want to have to go changing them every few months).
Have been looking for other options, the UAS pivoting arms look nice but at $595 they are way too overpriced for my taste. Also had my eyes on the old Noltec style (see pic below) arms but can't seem for love or money to find anyone who sells them or even a similar product. Anyone got any suggestions on where to look?
Cheers
Simon
unfortunately I'm pretty sure they are discontinued now. they are for sure the best type out there. very good value, no play, reliable and last forever.
you might be able to hunt down some second hand ones though.
Phwoar I just scored myself a set of those genuine Noltec adjustable control arms for my R32 last week on ebay. Barely used for only $180 :P
Been looking for a while. The guy said he paid $445.00 for them when they were new.
Looks like a I got a bargain. Very good to hear that they are the best type out there. I was never going to waste my money on the ebay china ones.
Good luck on the hunt mate. The Silkroad ones look good (they are a trusty Japanese brand, I use their coilovers) however a pair of those will cost you $500AUD+ easy.
Edit: Yet to fit them but when I do (in the next week) I'll let you know how they go.
Edited by -Jimmy-
the UAS ones may look expensive, but they are a step above in quality compared to pretty much any other option.
these are the upper arms out of my race car, demonstrating why the pivoting arms are important
Damn you for posting that picture!
Another group buy on the pivoting arms, extra $200 mark up is just taking the piss :(
Edited by SimonR32
OUCH!! What happened? did the bolt snap or did the bushes collapse?
Are those bushes shown in that picture the same kit as this?
I just bought this kit from Repco for $130 trade, was going to fit it in the next couple of weeks.
Are you saying that they are no good?
It depends what you use them for, how much castor you run and what ride height you run.
I have done a similar, if less dramatic thing to that style of bush in one track day. Basically the rear outer upper bush gets flogged out quickly. The solution I came up with was to use a harder bush in that position. Not had any trouble since.
The compliance in the suspension is mostly in the castor rod. So if you run a castor rod without decent compliance and that style of bush kit you will be in line for an issue - IMHO anyway.
Duncan's case is probably worse because he has to run stock rubbbish on a race car. Here the only workaround it to modify the attachment points of the inner arm at the bracket - this allows the arm to rotate. Which is pretty ugly.
Also if you look at the Cusco fixed length arms they have (in plan view) a bigger offset. Something like 22mm instead of approx 15mm stock. This means less castor & presumably less load on the bearings that the Cusco arm uses.
Interesting points... I've got kazama castor rods so they should have little to no play! When you said you used different bushes on the outer rear, want to help us out with some more info?
Well there isn't much more info. I took a bush, measured it up & then went down to a local plastics machine shop and asked them directly what can you make this out of - it is for a car suspension bush and needs to be stiffer than this stuffed one? For the price of a carton of beer I got a couple of bushes - I am not 100% sure what they are. The key bit is they need to be sitffer than the stock ones so they don't get "pinched" by the arm.
The other solution to all this is buy the Nismo suspension link kit.
Haha, dam that sucks... I'm still 50/50 on installing the whiteline gear because i'm planning on hitting the track a bit and don't want to waste my money if they are going to shag out straight away
hey duncan,
was wondering what type of adjustable bushes they are?
and whether they are adjustable with the arms in the car. i ask because ive read that a few of the caster rod bushes require the arm to be taken off so im not sure if those manufacturers have designed the other bushes the same way.
going bushes to stay compliant with general racing rules and regs.
unless you have everthing stock. ie camber, caster, ride height the bushes will flog out... if anything is changed the upright wants to tilt off the original axis and twist a couple of degrees.
the midori style arms work for a while but because of the twisting motion they always come loose and eventualy the thread will gall up ans make a creeking noise.
the uas ones are more expensive but do not bind and are very easy to adjust.
i have replaced many adjustable arms, noltec and all the differant adjustable bushes. (my grubby hand in duncans pic) for some reason the light blue bushes in the sliding arms turn to powder.
and for the record each uas arm is hand assembled to matching components to ensure reliability and function. this takes some time to do hence the extra cost.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
