Hey guys. Haven't posted here for aaaages. Was a while without net and then a while without my license, so this was just a tease, lol.
Back on the road now and slowly getting on top of my finances so looking to maybe get some stuff done to the Stagea again.
So I think its about time I replaced the brake pads. For starters I think it's been about 25,000kms of typically fairly aggressive driving since the brakes have been touched. Secondly I'm now having a very quiet scraping noise coming from my front left wheel when I brake, which I believe would be due to very worn pads.
Now I've been pointed in the direction of Lucas for brake pads as apparently they're very good value for money. Good performance and a good price tag.
If I was to go down this path, I was wondering if anyone would have part numbers to suit my '99 S2 RS4-S??
Also, while replacing the pads, I thought, if affordable, it might be worth upgrading the rotors. I don't need/want anything extreme, but having something a bit better than stock to back up the 180 odd kilowatts at the wheels (which is a figure that will only get higher) would be reassuring. I looked at Brembos in the past and they are way out of my budget.
Was just wondering if anyone knows of some good rotors for a good price that would be a nice, modest upgrade for my beast?
(part numbers would be very helpful with any suggestions if possible - Thanks)
Thanks everyone :P
P.S. I had a brief squizz through the brakes thread, but shit... It is a massive pain to read through even a quarter of it when I can only view one post at a time!!
Edited by Unbalanced
https://www.sau.com.au/forums/topic/327121-brake-upgrade/
Thanks everyone :P
if i remember correctly, R33 GTst brakes or r33 gtr brakes or r32gtr brakes, or r34 gtt brakes if you get the whole set up, but for the r33/r32 brakes require some alterations to the brakelines as per brake thread.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5323581
I just upgraded my fronts with Sutimoto 4 piston calipers, can get them off R32 gtr or Z32 300zx (with cooling fins) or off R33 (No fins), the fins make no difference, I found that they fit perfectly on my S1, just had to remove a little orifice from the fluid inlet and I was able to use my standard brake lines with banjo bolt,
to remove the orifice basically get a corse screw and screw it in and then use a claw hammer to pull it out
give the aus300zx forum a look, those guys sell there calipers alot cheaper than the R33 guys, I got fronts with good pads and with DBA4000 slotted rotors for $200,
the calipers use DB1170 pads which are pretty much a standard shelf item in most car shops that ive been in
P.S while your looking at changing them out give them a splash of paint, works wonders in the looks department.
Edited by briggsey
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5323843
option 1:
qfm hpx pads + slotted rotors
(both off sellers from SAU)
option2:
r34 front callipers (r33 need bushes making up to stop the slop with the 12mm bolts and 14mm mount holes) + r34 310mm rotors
option 3:
r34 gtr brembo's
option 4:
Cheap 8 pot brake kit from Justjap
($2200)
i went with option 2, but i've gotta run spacers on the front to clear the inside of the wheels but aside from that they seem good
option 1 is the cheapest and will take a fair bit of work to overheat and fade and the qfm pads make very little dust too (i'll change to those pads when funds free up)
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5324082
Hi Adam, if you look at Cheap upgrade then,that work`s well,
RDA SLOTED ROTOR`S, pad of your choice ,brake stopper, braieded line`s & some good fluid,,many change claiper`s but the big PAD work`s well on sloted rotor,
so good luck Cheer`s Chuckie.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5324157
Hey guys. Just an update.
At the moment I'm looking at DBA slotted rotors, braided lines and some Bendix Ultimate or Lucas pads.
Will be getting it all priced up over the weekend and hopefully get it all purchased and installed in the next two weeks.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5325409
series 2 needs r34 brakes . series 1 needs r33 brakes .
due to mounting bolt sizes
then maybe something like this
http://www.trademe.co.nz/Trade-Me-Motors/C...n-300487234.htm
Well after all the talk about R33 brakes bolting straight onto my S2 Stagea, I discovered today that I was mis-informed! :P
Got a set of R33 rotors, calipers and new pads ... and just found out for myself I've wasted my money and time trying to fit them today.
Is there any option for a 'caliper relocation bracket'?
Anyone want to buy an R33 brake kit for their S1 Stagea?
Anyone got an R34 setup they want to swap for an R33 setup?
Really not happy atm. :)
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5326504
caliper relocation bracket?
i'm assuming you are having problems with the caliper mounting bolts being different sizes? r33 is m12 and your car m14?
if that's the case, just get some sleeves machined up (pretty sure you could prob buy them already done somewhere as it's a common issue) that are 14mmOD and 12mmID to fit into your knuckle and use the m12 bolts to fit the caliper :P
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5326582
qfm hpx pads - as good if not better than the ultimates and very very little dust compared to the ultimates
i've got lucas twr pads in mine and they seem pretty good, but i haven't laid into them much yet - fairly dusty tho
i had the same thing happen to me - it sucks
hardly any import wreckers have 34 brakes either but try this guy
http://stores.shop.ebay.com.au/Skyline-spares__W0QQ_armrsZ1
thats his ebay store but give him a call cos he regularly has 34 brakes in stock - cost me $300 for the callipers + postage but i think i took his last set
Edited by pipster11
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5326630
Thats not the biggest problem. I wish that that was all I had to do.
The legs on the Sumitomo calipers are too short (in radius) meaning even dummying the calipers in place, the 297mm rotors are too large for the calipers suited to them (on the R33, but on the S2 Stag they don't work). I even toyed with dummying in place the 280mm rotors and the calipers still fouled on the rotors (even when I spaced out the offset).
So the R33 GTST calipers and 297mm rotors have the right offset, but totally wrong radius (by about 20mm); and
The R33 GSTS calipers and Stag 280mm rotors have the wrong offset, and still wrong radius (by about 3mm).
Something to do with the 14mm bolt pattern for the calipers being close to the centre of the hub.
Well I'm screwed now, because I had a time attack in 3 weeks, and a brake upgrade that isn't working and I've blown money on it already.
I'll give the guy you mentioned a go.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5326704
So the disk is too big? Can you just machine the disks down?
If I machine the R33 rotor down to suit the R33 caliper on the Stagea, I'll have about a 270mm rotor left. Less than the stock 280mm ... thats going backwards.
Getting rid of the 33 stuff and hopefully come out of it enough to get the 34 stuff.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5327067
that doesnt sound right . they should bolt on . its just the bolt diameter that is wrong . maybe someone sold you different calipers labeled as r33. i dummied some r33s on my series 2 and it was right apart from bolts . you can even buy step down bolts on import monster
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5329565
i also trial fitted a set to my auto stagea and found the same thing, a set of R33 GTST callipers would bolt up with the only issues being the bolt size on the calliper mount, and the brake line was a little different requiring removal of the flare fitting in the calliper or shortening the banjo bolt.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5329774
Was just thinking to myself R33 turbo and R33 N/A brakes must be different yes? Thus why he's having issues?
I have R33 GTST brakes for sale fronts only.
Sumitomo calipers with pads, and 297mm rotors. Yes, I just discovered these do not fit series 2 stagea (but do fit series 1 stagea, and non-turbo R33, and others). Now I need these sold to get my R34 GTT calipers and rotors.
https://www.sau.com.au/forums/topic/327121-brake-upgrade/#findComment-5330385
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
