Hi all,
Thought this might be an interesting thread. In my case I have an R33 with a turbo abck exhaust, std airbox with BMC panel filter and an R34 SMIC.
I found this to be a good mod with my basic level of modifications adn allowed the car to rev more freely through the rev range and appeared to have a little more sting although not much.
Now with my level of modification and standard boost which is where the car will stay for the short term I am not keen to put a FMIC in just yet. At some stage I will upgrade the turbo with all the supporting mods but that can happen as a package. This is really about a easy DIY mod at low cost.
Now I used the r34 front duct on my S2 33 bumper with only minor triming required. I also cut every second 'slat' out of the exit in the wheel arch to stop hot air from banking up behind the core.
I was wondering about the thermo fan option. Ie wiring an 8ish inch thermo fan on the the back of the coor or the inner gaurd area to force hot air out and increase flow through the core in traffic (thinking ahead for summer here)
Would this make a significant difference? I imagine it would stop the traffic light heat soak, or at elast help. At high speeds would the fan rotation cause a backpressure in the core? making it harder for air to flow through?
thoughts?
https://www.sau.com.au/forums/topic/327405-thermo-fan-on-smic-discussion/
id say probably wouldnt make any sort of worthwhile difference. i think your kind of splitting hairs to be honest. yes it could possibly help cool down the cooler when sitting in traffic but thats when having colder intake temps by 1 or 2 degrees is really not necessary as theres a very negligible amount of air flowing through it in those circumstances. once the car gets moving at all then the smic will be naturally cooled by the air and a fan wouldnt be making any significant difference
listen its a "ok idea" but ur not really going 4X4 driving are u to need that slow moving cooling.... the car is engineered to go fast hence it dosent have a water cooled intercooler.... if u can somehow attach a viscous fan to it lol then go for it :bunny:
I wouldn't bother. I was making 220awkw with a smic including track days. Granted it was a Nismo one, slightly more efficient than the R34 stocker but at your output you should be fine. Wait til you get the monster turbo and then go straight for a quality front mount.
for the op if I think what your up to doing id take a look into the Cima VQ30DET side mount intercooler and add a fan + a water sprayer but the prob is you can just go for a fmic kit but if you dont want to go for the mod look then i'd say your on to something good but need to look at all of the options.
I did hide the inter cooler and doesn't attract much attention and the funny things here people walk up to me asking to sell me an SR20DET swap for my car and i just let them yap on I just smile nod and go about my business,
yeah this was something i had considered. The core seems to work well, even after a long drive the cool side is still ambient or cooler and the hot side is barely any warmer. So for my application, daily driver with the odd squirt in traffic it seems to work well. was just worried about summer thats all
put a water sprayer on it . wouldnt bother with a fan . its not going to heat soak in traffic , are you on boost (compressing and heating air) as your sitting at the lights or diddling around town at 50kph ?
no .
It will lower your intake temps by 1 maybe 2 degrees if your lucky. However it's easy enough to hook up diy spray kit to the water bottle and a micro switch so it only comes on at WOT.
You could always look at meth?? Although not excactly cheap!!
Edited by jjskyline79
You dont want it spraying at WOT. The core needs to be wet/cool before you come onto boost.
Thats why the Evo/WRX sprayers on "Auto" mode spray when you brake.
it will be more than a few degree's difference if done correctly
as adriano said subaru and mitsu didnt do it for fun and certainly not for two deg temp drop on the intake
i reckon ballpark it would be a drop of 15-20deg would be more reasonable when done correctly
ie compressor outlet 75deg after water soaked intercoller core sub 40deg air temp
taking into account the intercooler itself will drop the temp too
to prove how useful it may be
blow hot air onto your wrist (where you slash if you are trying to kill yourself / EMO)
now wet that area with water or just lick it
blow how air again onto the same area
Fan force SMIC
http://autospeed.com/A_110214/cms/article.html
http://autospeed.com/A_110215/cms/article.html
Intercooler water spray with results;
http://www.mearcat.com.au/kits.html
http://www.mearcat.com.au/coolerresults.html
Intercooler water sprays work by having atomized water droplets evaporating on the core. The evaporation process absorbs heat. (Exactly how sweat cools your body down, God didnt install that on us if it was only a couple degrees difference :banana:)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
