Checked recent Posts/threads and theirs nothing useful to help me so ill start a new thread!
Ive read in past threads not to trust brant security anymore as one of their installers is stuffing up...
Im really interested in Viper and Clifford Alarms, and was wondering what would be the best company to get it installed through?
I need it urgently as my insurance states i need to get an immobiliser alarm by wednesday of this week to be covered :)
Im looking to spend maximum $850...has anyone had a viper or clifford installed? and if so where did you get it installed, or if anyone knows of where i can get this type of syystem installed would be greatly appreciated
Also Remote ignition start, how come they say you cant have it for Automatic Transmission, yet some people say you can have it for manual
Thanks in advance :(
https://www.sau.com.au/forums/topic/32789-car-alarm-security/
tim... it doesnt matter what alarm u have in ur car, if they want something from it or the car itself they will get it.
get any half decent alarm... dont go spending a fortune on an alarm.
get danny from autotrust to do it for ya... and if you're real nice to him you can wake him up at 3am for after sales service when your battery dies and you can't do a rolling start of the car. :P He's on the forums and he does a top notch job, even goes out of the way to make sure everything is neat n tidy and inconspicuous under the bonnet and behind the kick plates.
Just don't mention roosters or vortexes around him...
he did my viper couple of years back and I've never had any problems with the alarm cept for when i trigger valet mode by mistake when i have the door open.
lmao oh what a funny night that was...
Yea thanks for your help guys
And u have a point nark but i sleep easier knowing i have sensors on every inch of my car :P just in case some lil toss is trying to get :) i can get outside in time...
Im definately going to go with danny at auto trust, after receiving some other quotes :)
Go to any freeway car audio store, there one in dande and 1 of my friends works at the malvern one. They can install those alarms
are you talking about ricki? Ever since he has become the manager of the Malvern store, he has become the biggest f*cken arrogant tosspot...to the point where I think Im gonna have a word with Michael about it
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
