  • Replies 68
Posted Images
Just grab the usual injector, pump and ECU upgrade and enjoy the power. I assume you have a manifold and know this wont go near bolting up to the std manifold. If you decide its too laggy for you then I have an 8cm housing that will bring it on qbout 300-400rpm earlier that i would be interested in swapping for your 10cm housing
my favourite RB25 turbo setup. I have done about 6 or 7 now. The latest was low mount external gate. 320rwkw on 18psi completely std internals.
You will love it, should be reliable if done correctly.
This is a customers 4door R33 (std internals apart from 260 drop in cams and no vct) 6boost manifold, blitz gate and T67....
320kw!
that is massive... i've got 280kw with 17psi
Ill be making a manifold or adaptor myself. What is the boost limt i can run and what power at which psi have you guys seen with this setup? Also where can i get springs for the trust wastegate?
i have a high mount trust manifold here i've been tryin to sell if you want, make me a reasonable offer and its yours.
Just had the car pictured above on the dyno, only change was we fitted a set of Camtech drop in's (http://www.skylinesaustralia.com/forums/Rb20-Rb26-Rb26-Camshaft-t308743.html) Car still has std head and bottom end.
Blue is before cams.
Red is after cams.
Nope, thats why ill get it going on say 7psi now, then buy pump , injectors etc. Any more advice or info to help me along?
dude
seriously u should listen to what ppl are saying, dont just go strap on a large turbo with no supporting mods
a
just do the basic stuff
ecu or piggyback
injectors
nice dump pipe and exhaust mods
and a turbo manifold
fuel pump
then the other stuff later, u will f**k something up by doing it the way u intend on doing it, + the lag that will happen and then only 7psi comes thru might as well leave it stock till u can afford to do it properly
dude
It seems you have missed the OP's topic all together.
He is asking what else is needed once he has this turbo bolted on, and what he can do with it in the meantime. I dont see an issue, chill.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
