it's a how long is a piece of string question really.
what type of driving are we talking? urban only? mix urban and freeway? mostly freeway?
on mostly urban with a little bit of freeway, i think the best i got on 98 was around 11.2L/100km with my GT-T. Which was about 440km and then the light clicked on.
350km isn't that horrible if there's some spirited driving in there.
Also, we have no idea of modifications, aftermarket ECU etc etc etc etc etc etc etc
Yous all suck if you're getting under 400kms to a tank in a non-GTR.
I just did 463km, with 315kms of that of spirited run to Bathurst and back.
what about us in gtst's that make more power than most R's?
pretty sure that when you modify a car to get more power and you need bigger injectors/fuel pump etc.... it's gonna use more fuel
seriously, we dont drive sports cars to get "aconomy"
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
