Yous all suck if you're getting under 400kms to a tank in a non-GTR.
I just did 463km, with 315kms of that of spirited run to Bathurst and back.
Why should a GTR be more fuel hungry?
My motors:
RB25, 270rwkw - 450-500km around town, 550-600 freeway
RB26, 280rwkw - 450-500km around town, 550-600 freeway
Identical :D
Pretty sure i have a 55L tank as well (never run it much below 1/4)
All of mine are with a nastier diff ratio as well, so I am doing high RPM @ 100km/h to you all :)
That said, if i get onto the loud pedal i can mince a tank in less than 300km's
am i the only one that doesnt check or work it out? i just go and fill up whenever i need to no matter what day it is, usually when i have about a quater of a tank left and thats it, i dont even look at the price when im filling up lol.
LOL +1.. always find vortex 98 for her and fill up once a week. its never been low so i never worry about it :)
I'm lucky if I get 350ks beween fills. And then it takes around 50Ls to fill it.
I'm wondering if a new o2 sensor will improve things, along with a Nistune and dyno time.
LOL +1.. always find vortex 98 for her and fill up once a week. its never been low so i never worry about it ;)
Once a week!!!!!
God damn. If I fill up 3 times a week it's been a cheap week.
Wish I was like that, but I'm obsessed with the trip meter haha. It can be a good way to tell if your car isn't running properly / as good as it could be. I do fill up whenever I need it though...stuff holding out for queues and cheap prices to save a couple of dollars. If you bought a Skyline for good fuel economy you did it wrong from the start I say!
Yer! Give the O2 sensor a go mate, it should be standard with every purchase of a Skyline haha! Instant 50-60km extra to a tank if it ain't been changed before.
Ummm.... ;)
BP Ultimate: 141.9c, 423.6km, 49.34 L = 11.65L/100km = $16.53/100km
BP Premium: 134.9c, 265.2km, 34.87 L = 13.15L/100km = $17.74/100km
BP Premiun: 134.9, 446.3km, 53.74L = 12.04L/100km = $16.24/100km
BP Ultimate: 140.7c, 476km, 51.12L = 10.74L/100km = $15.11/100km
Caltex Vortex: 143.9-4c = 139.9, 300km, 35.54L = 11.85L/100km = $16.57/100km
Sucks that BP Ultimate is currently the best, I want to boycott them bad. Going to move onto Mobil and Shell soon, hopefully they are awesome.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
