I love all the noobs who cry when someones car isn't sitting on the ground... they finally buy a car, dump it, drive it for 5 mins, turn the kit into a horrible, cracked nightmare and get defected 500 times... parents yell at them so they sell car... but because they had an import for 5 mins they're now experts
from someone who has been driving imports everyday for 8 years and has never been defected you may now kiss my arse :nyaanyaa:
hella flush might look cool sitting in a car park but try driving it round the streets of Melbourne like that... good luck kiddies
ps. nice Chaser... needs more low tho;)
Ok... Which side you on?
:P
Yep. Im a 'noob'...
if you cant drive then your going to have issues if you have some driving ability you'll be fine AND look awesome.
its horses for courses if you dig fitment and shit then thats cool if you dig autosalon and dyno's thats cool i dont ask anyone to like my car and dont ask me to like theres everyone should think this way and just be able to appreciate the work which has gone into it. thats what it is really about.
so yo foolz stop hating on each other ya both got shitboxes.
:laugh:
ash why u sellin bro?
  • Like 1
nah here u go, your turn to give me a hard time ^_^
+ i never said ur car needs to scrape the ground. GTR's dont need to be slammed. minimised tire to guard height + strong offset = GTR stance and presence ^_^
same theory with all cars i guess.
Edited by drftps13=D
  • Like 1
Which pic is the most recent? Silver with gardening edging looks good....
Was 1 of those pics taken at 7/11 in Richmond?
Fitment is tight and stance looks nice.
thanks mate
yeah the pictures with factory aero are that that 7/11. with the BN kit is a different one.
stance is good, fitment on the front is perfect, I need to reduce the camber on the rear to get the fitment right,
i literally just put the stiches on and didnt have a chance to adjust my camber arms- was running 17x9.5+17 XD9 on the rear for an hour to get to a mates place lol
what are the meshies on the black GTR fronted R32?
also, are those stock headlights on the silver r32 with garden edging?
nice.
grant- congratulations man!
if you dont want your N1 bootlip ill buy that too :P
Edited by Mohsen
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
