All good guys I've learnt my lesson with my first car the VLT, tried to do a loophole in the law and cop's let me off (Insurance was another story), got written off and found not at fault but scared the bajeezus out of me, now I have a work exemption to drive this so insurance is fine with that. Absolutely in love with this car I don't even care about the power it's just the sound for me I think, I've missed intercooled turbo's thats for sure :P Can't wait for a track day! I think what they say is right though you don't really learn until it happens to you or someone close to you, I came close enough for me to re-consider how I drive every second of every day.
Edit: Have realised it's almost a twin of PM-R33 without the carbon mods and such he has.
Looks great man. Congrats. I still remember when you bought that silver horror from Sydney.
Haha I hoped everyone had forgotten about that :P nah she's still tucked away in my heart that one, first skyline ever the biggest dud. Second one... not much better but still reliable, this one though is just wow.
lol i wont forget it because i almost bought it!
best of luck with this one :thumbsup:
Edited by Mohsen
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
