that depends... will you be sitting in the car?
boom
lol
the real irony here is that nick had an evo that was better than both of ours lol
haha, you just need time to work them up to what mine was :P
Put together.
Nick. I looked up to you bro, now all I see is vag
yeah so do I, can see my car outside right now :P
The garage down the bottom where the gtr is parked is a double double double double if we want to talk burger sizes, or an 8 car garage.
The shed you can see up the back with my r34 and sileighty is a 3 car plus a hoist, which is the bee's knees
lol, I spotted what I thought might be your white 34 (recognised the Boost For A Cure stickers) at Genesis Wantirna tonight...came on here to ask if it was you...saw your username and it's only just clicked to me who you are *facepalm*. Thought you'd sold your R34 already and I'm used to seeing you in the 33R...thought it was someone else's in the parking lot.
Should have clicked when I first saw your garage post lol.
Heh yep i'm me :P, nah have not sold the white r34 yet, has come in handy to use as a run around car recently :)
if he wants a stanceworks sticker then so be it... he likes to hang around with those people, so it makes sense...
hey mo, do they have a rainbow one out yet? :P
sif not follow my thread, quarter will be painted soon. then whole car stripped back and redone in PPG because debeer is shit
Why didn't you do it in PPG in the first place?
I was thinking two dolphins jumping. But styled like cocks over a rainbow.
Because mohsen
lol yup
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
