Here is my 'project' car. One day my dream car after I spend a lot of money on it.
Some of you may have seen it (me and my husband) on Saturday at Racepace
Place looks familiar! Seriously listen to these dudes on here / same thoughts as me on the engine build.
First new oil pump, sump mods, water pump, fuel pump - then look at turbo's, exhaust, new engine loom and ecu, intercooler, radiator, oil cooler before opening engine and filling it full of aftermarket stuff. IIRC your car is spot on compression wise.
yes and no....
would be silly to upgrade oil pump and not do custom drains and restrictors... might as well just not put oil in the thing :P
I
Saw it on aus-vip
Winner with black leather, any mods planned?
Haha, of course!
Already got VS-XX coming and trying to make up my mind on what suspension to use to go a little lower.
I've also bought a K-break grill and now doing research on whether it's easier to fit Z33 brembos or z34 Akebonos :D
Haha, of course!
To which car? I just sold a set of Akebono's as I didn't want to run 19/20's.
Edit: Just clicked the link.
Are they the same brakes as the 350z touring?
I don't know, I've only just started reading stuff.
Over in the US, they've put both brembos and akebonos on these cars but I'm not sure how much modding needed to happen. I also read some people over there were having some success with fitting the CZ Performance Akebono conversion kits for z33. Again, not really sure if they were bolt-on or not.
yes and no....
Yep!
Also people under-estimate certain OEM parts.
And do the short cut round.
Haha, of course!
Oh nice will look good by the sounds of it!
Was hoping to go a full k-break kit for my majesta, but those $$$$$ :P
  • Like 1
Yea, K break make nice looking kits with price to suit but they're a lot cheaper than Junction Produce. Love the JP kit for the y34s but they're way too expensive :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
