Well apparantly the wiring along with my head unit is a bit screwed up but the guy I bought it off said that before he put the head unit in, the MFD showed everything minus the turbo bits, so shift light and what not, all worked. Need to look into fixing it soon.
Currently all the buttons work but doesn't show readings (just 0's). :/ Only thing on the display that actually corresponds with the car is the Oil Pressure!
I see...
Well at least one of the most important readings work... Oil Pressure! :)
:thumbsup:
real talk, it's just a lancer with a body kit :ph34r:
good work :cheers: lol that's what my mate said about his emo 7...ended up crashing into someones front lawn and wrote it off. :/
540711_10151711848842762_1118303854_n_zp
It was saa nice as well...well for the three or so weeks he had it for.
cheers brah. but lol wut... :/
should i even ask wtf he was doing for that to happen... LOL
technically it's a lancia cedia chassis with a widebody kit, seem welding, a bodykit, different suspension, different engine, ACD, AYC, bucket seats, aliminium panels, and better everything else
also advan RG are sweet wheels
This man knows his cars. :worship:
Haha if you're ever close by just gimme a buzz, else will see it when headlight's get blacked out! Be interesting to see what you think compared to your old VII?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
