hi guys. what power have you done on standanrd bottomend rb30s and on what boost and what turbo? il have mine going soon and wanna know what power you guys have done.
mines a rb30 bored 1mm oversize with new mahle pistons and rings and king bearings. standard rods and bolts. has rb25det oil pump on crank collar. what power do you rekn itd do on 18psi with a t04z with split pulse 0.84 rear? hopefully not too much for standard motor. hopefully want it to cop 450rwhp for a while on pump fuel. i dont really thrash my cars everywhere but that might change when i get one with a bitta power.
does the ones ripsnz have on youtube saying standard internals have anything done to them special? ones running 25psi plus 100hp shot of nos. its 650whp it says i think. and few other ones with heaps of power and he says there all good for that power. just been wondering if he does any tricks on them to make them last.
https://www.sau.com.au/forums/topic/329976-standard-bottomend-rb30dets/
  • Replies 43
If you have aftermarket pistsons and stuff... Why are you asking about standard bottom ends?
Either way if you only want 450rwhp, the T04Z is a very bad choice, a GT3076 in a 1.06 would be the pick for 320-330rwkw.
A T04Z is 600rwhp territory. A signifigant difference.
there only cast pistons so id assume theyre about the same strength as the factory nissan ones. and the bearings wont help it take any extra power would it? the rest is standard nissan stuff.
will get more power out of it later. only wanna buy the turbo once but.
If you're buying aftermarket pistons then why go cast? save a bit more and get some forgies.
But really, how long is a piece of string?
Good balancing, good balancer and a good tune should see it live a longer life than if you did none of those things.
i have done the same and just used some aftemarket cast pistons as they were needed due to worn block and only cost 300 bucks with rings. If you do forgies then its the rods as the weak link and then oil pump and on and on it goes. I decided to save the $1750 and just limit the setup to under 500rwhp. I have one engine running a 3076r and its currently not running the correct cam timing so power is down but its running 22psi and 330rwhp. This shall be retuned very soon to around 400hp or so when i get some spare time to do it. Another engine the same exact setup will be using a hks t04z and we shall see how it lasts with 500rwhp or so. Just finishing off the final touches to the donar car at this stage so wont be running for a while yet.
I'll let you know as well. By accident rather than design I will have all the good gear in my sig on an RB30/25 stock except for new rings bearings and rod bolts. [Would have preferred to have it rebored forged pistons and balanced] With the stuff I have it should make the 500hp ok but for how long is the question. I will be relying on a good tune and 6,800 rev limit to make it last so if it doesn't quite hit the 500hp so be it. Anything over 300awkw will be a bonus
r33 N1 turbos are supposed to be good to 550 hp at the engine.
Im shooting for 400 atw or 18 psi what ever comes first, But the small N1 should give great throttle response
http://homepage.ntlworld.com/tbroom/Turbos.htm
I thought N1s didnt have great response for their size, so you could go a larger newer turbo that would have the same response but better top end.
Yeah but I have the turbos and will go with them until I feel like i need more.
if I can crack 400 at the treads it will be enough
Pits will be tuning it and the brief will be 18psi or 400 when you get to one of those stop
Slappers on big turbos do NOT last long...
I've broken 2 now... With a max of 1000KM on them... Pushing 1Bar (14PSi) through TD07S housings, t66 front and a t04r rear wheel.
Nothing below 4000/4500RPM, then everything ramps in over 200/300RPM...
Rev limited at 6600RPM.
On the dyno it made "250RWKW" wheel spinning like a spastic... Using fuel consumption and AFR it would be making around 360RWKW... (69% inj duty on 880cc injectors)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
