Yeh, my old R31 had these rocker covers on the the later model R32 engine it had. I left them the std R31 colour and just rubbed back to ribbed tops. I think they woudl look better if they were the std R31 colour rather than lipstick red...but meh. By the time they are covered in blow-by wont be able to tell :)
Well my 20G is going to be for sale once the new engine is tuned and run in. It seems 350rwkws is about the mark for a basic Skyline doing track work with E85 these days so need to go to billet or T67 to get there.
God that is a lot of power and going ot be painful to get oil and coolant temps under control :( Whole new suspension and rear end and diff about to go in as well so the car will be like new. Just have to decide whether I want alloy tailshaft or carbon
They are Tein RAs with custome valving and different springs. From memory they are 8F/4R or thereabouts. Need to check. New stuff is the same thing just that they are GTR gear so have the forks rather then eyelets so suit the new rear end I have. The GTR gear is being revalved almost the same as my current gear and I am throwing a bit more spring at the car as I have softer swaybars now that I went from custom Whitelien to ARC so needs a bit more roll control. I may end up going back to custom swaybars if the higher spring rates do things to the pitch that I dont like.
What are they worth. Well RussGTSt is selling very similar Tein REs near new and has had them up for sale for ages as he cant move them...so I guess less then that though my hoarding whore self may just keep them as they are near new and still shiney
Yeh, back in 2001 my car was the development car used by Whiteline to develop their Bilstein kit, swaybars etc. I kept that kit to around 2008 when I changed to the RAs. I almost got the Bilsteins rebuilt to be a little more racey but the Teins being alloy body pretty much sold me on them.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
