That looks really good. Is there no joins between sheets of vinyl (were you able to do a whole panel with just one sheet of vinyl)?
I thought with this idea there would be visible joins but I have to say it looks really good
  • Replies 161
well done mate looks really good i recon.
must be fun having just changed the entire look of your car over a couple of weeks!
Cheers, It really is, that said, there have been many moments where i spat the dummy and considered ripping it all of when it wasn't going the way i wanted it to... :)
Thanks :banana:
There are joins in the vinyl, thankfully they aren't very visible due to the color of the vinyl and the positions that i've placed them in
Thanks Lyndon, Thats the plan,
As far as exterior mods go its
-z-tune style side skirts and rear pods
-top secret gtr style front bar with lip
-nismo smoked front and side indicators
-Gloss or Matt black rims (Rota GTR's possibly, unless something comes up at a good price)
remaining panels to wrap
-finalize front bar
-wrap rear bar
-wrap bootlid after its welded and painted
-re-wrap drivers tail light
-finalize front bar
-wrap rear bar
Post pics when done!
Wow! When i saw the thread title i was thinking uughh should i bother posting? As id assumed you were spraying it. haha. Not many people realize that matt black breaks down in about 6 months in the sun and needs another few coats! LOL.
But this! It looks fantastic! Always thought the Matt finish looked pretty swish, but too many try hard gangstas with spray cans killed the effect. Well done. Its looking great.
Out of curiosity.. does it have any detrimental effects to the paint underneath should you decide to tear it off one day?
My old daily hack...
Only kept it Matt as its how it was when i bought it. Looked mint when i 1st sprayed it again, but this is about 5 months later. Goes all blotchy and poop.
Congrats. Your car now looks like it's worth $5k and is just a beater :)
Quite a naive comment i don't think you see the potential it has with the right JDM rims and a bodykit it will look great! there are very few R34's in matte black so it will be unique most likely putting up the value of the car.
Lol. thanks dude, i've seen a few vans in matte black, usually young dudes getting around in them heh.
If you paint is in good condition it shouldn't cause you any problems, nothing more than a nice clay bar or cut and polish cant keep looking gorgeous.
On the other hand, if you paint is farked, expect to rip some of it up as you pull off the vinyl.
Congrats. Your car now looks like it's worth $5k and is just a beater :P
:) thats ok, im happy with it
yeah so does this sack of crap :ermm:
that is certainly a porn lookin sack-o-crap, one of my inspirations for doing it myself. :P
Cheers.
Even if it doesnt do the cars value any favours im loving it. and as you said, there are very few 34's getting around like this :)
Never realised this thread existed, only saw one pic u had in the 34's thread. And i didn't realise u wrapped it in vinyl!!!!! thats crazy man! haha but i think it looks mean as. Funny tho at one stage i had the exact kit that u want to put on sitting in my garage doing nothing. But i sold it, just changed my mind and went for somethin more simple. I cant wait to see it all done complete with wheels etc. Even without the kit on and just a good suspension setup with wheels would do it for me.
Smoked indicators will suit much better than clear now that i think about it. Well done dude from photos it looks flawless, probably easier to see dents it seems, but i couldn't see any from pics!
Personally i would strip the weather shields off they look much more noticeable now. Wicked man ;)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
