This is my daily to drive to work, I own a printing company, sometime I find a bit hard to fit jobs to urgently deliver to my clients but i still can manage to fit about 10 boxs of A4 paper in the car on both the boot and the front seat with the roof open. :ermm:
This is my daily to drive to work, I own a printing company, sometime I find a bit hard to fit jobs to urgently deliver to my clients but i still can manage to fit about 10 boxs of A4 paper in the car on both the boot and the front seat with the roof open. ;)
LOL, I don't think the "urgent" delivery would be too much of a factor if you're using this for deliveries (of course, assuming there is little or no traffic, and that you are adhering to all the relative speed limits like you should), but the amount you will be able to carry to each destination would be more of an issue.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
