i want to drop my r34 (with the standard bodykit) and i want to keep my ride quality as much as possible as im not worried about going fast around corners or anything so would lower springs be the way to go? maybe some do's and don't, brands and prices will help.
p.s i am tying to limit how much i spend so money saving suggestions would be great!!
https://www.sau.com.au/forums/topic/331808-best-way-to-lower-an-r34-gtt/
get lowwer springs but your ride will change as if you are going to lower your car uou will need stiffer springs to compensate for the redused up/down travel .
another option if you know of a work shop that specializes in leaf suspention (usualy found in 4X4 mags) they can heat and compress your springs slightly to lower your car.
DONT cut the springs !!!!! hit a bump or get airborn and your spring will fall out (been there done that )
Lowered springs (King Springs, Pedders, Lovells) on standard shocks is probably the cheapest option.
- Pros: Cheap, looks ok (if that's what you're after)
- Cons: Increased wear and likelyhood of failure on shocks, worse handling, etc.
Read SydneyKid's Lowering Springs With Standard Shocks thread for some more info.
  • 3 months later...
glowstreet the gt-r shocks wont fit im quite sure, i have a set at the moment that i got off a friend for free, took em to a mechanic and asked if it would fit and i found that the front 2 will fit, but the rear 2 will not
On a GTT it will fit all the way round. on a GT or a 33 GTST it won't fit the rears. The fronts are also a lot lower but the rears will be same height
Whilst it might fit, everything I've read says it will be entirely the wrong spring rates, etc for the car. Apparently the GTR weight distribution is quite different to the GTT (4WD system, engine differences etc). This information has been posted around the forums a few times by people in the know...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
