The greatest aspect of the R35 for me is, you can slap on some decent rubber, flash in your E85 tune (thaks M :thanks:) and run near supercar like times at the track. At the end of the day, road tyres back on and literally drive home in leather clad comfort, climate control and all the fruit. Not to mention TRUE road manners.
This sort of versatility is surely unmatched, let alone at this price.
BUT.. for you regular track goers, are any of you worried about not having a cage?
I wonder did Nissan anticipate this at all.
And btw, did they run a cage in their Nordschleife record setting attempts?
Does anyone have any info or data on the strength of the car?
They spent a lot of time engineering this car, I wonder how strong it is, or how it would "perform" in a decent shunt?
Who would know you think?
Edited by LSX-438
https://www.sau.com.au/forums/topic/332974-r35/
glad you are asking that question....your lap times at Eastern Creek are excellent but they reflect that the car is going extremely quickly. In fact you and Marek would have the fastest non-caged cars ever at that track I bet.
The reality is it will only take a single critical component failure and you are into the wall at 250+. I broke a castor rod there years ago, and I understand Stu had a wheel bearing seize just last week. It does happen, and then all you are is uncontrolled momentum.
I only know 3 gtrs locally that have been written off (Leehmuis, Quinn and Jones), all had full cages and all walked away from a destroyed car. Kel was in the car for one of those crashes and can confirm it hit hard but kept it's cabin protected.
No idea how you can judge the comparitive safety of caged vs uncaged, except remember that the uncaged car is designed to deal with the sorts of accidents that happen on the road, not things like big rollovers or straight on into a wall at well over road speeds.
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399308
I agree with both Duncans.
I have been increasingly concerned of my own mortality. You can keep pushing the limits in this car so far and it feels so safe but as Duncan says, even if you keep within the limits of your experience, you are traveling so fast into and through some turns that all you need is one critical equipment failure to turn things around real fast. Especially if you are punishing the car regularly and therefore more likely for something to go snap.
I am getting a full cage at the end of the year, and have the boys at mercury trackside as well as inspect everything pre/post track days.
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399328
We caged our GTR for this very reason. There is a point.....where you simply MUST have a roll cage thats to FIA spec to ensure you walk away from a track accident. We used some interesting design ideas to keep our cage compact, light, and strong without having it intrude overly on the driving experience. Everyone has their own thoughts on this, but I got out the old Statics manual and laid out the best truss I could for maximum stiffness and strength along with lowest bar count :)
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399417
Martin, what exactly is involved with putting a cage in. Is my daily driver gone?
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399522
Everyone has their own idea of what makes a cage.....
DD is possible, however you need to know what you are doing with the design to make it work. A traditional roll cage will make your car a PITA. A well thought out one will make it DD. Its a tough question to answer, like 'how long is a piece of string'....DD is perfectly possible :)
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399713
A good FIA standard CAMS approved cage shouldnt seriously detract from the value of the car. It will make it more desirable to those that want to use it in Tarmac rallying as this kind of cage is a minimum requirement :)
To give you an idea - we were able to integrate a structural roll cage into our GTR - without cutting any trim, save for around 5mm adjustment of the glovebox. The stock door trims fit, the stock seats fit (if you wanted them to), the front legs go past the dash without any cutting or 'chopping' The only thing you cant put back in without modification is the rear seats, however the idea would be to pad out the back Spec V style. As I said there are roll cages....and then there are roll cages :blush:
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5399758
Peter Leemhuis?
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5403129
Yes, Pete (sorry about the spelling lol). and that car was repaired and is doing gt cup now afaik. the other 2 are spare parts at best.
I would suggest checking carefully before assuming you can have a cams and road legal cage in the car. CAMS cages have to either be built to one of a couple of standard designs, or be fully modelled by an engineer to prove it meets the requirements.
I don't know the road engineering rules in each state but there are requirements about removeable side intrusion bars and minimum distance from bars to driver's head.
Best to talk to an engineer in your state to confirm how or if a cams cage can be legal.
Finally, under CAMS rules scruitineers can knock back a car with a non-approved cage, even if a cage is not a requirement for the event (ie they deem a non-compliant cage may be more dangerous than no cage at all). Make sure it is CAMS approved.
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5403894
surely you could get away with a much less comprehensive cage for a track car? (as opposed to one used for tarmac rallies)
most tracks have pretty good run off these days and tyre walls do a pretty good job at absorbing impact... that said there are some places at Sandown I wouldn't want to have something on the car break!
so are you mainly worried about a rollover?
would the 35's benefit from a bit more stiffness... they seem like they're pretty good in that area already?
https://www.sau.com.au/forums/topic/332974-r35/#findComment-5404671
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
