search engine doesnt let you search for "1/4" so everyone put drag times here
spent 2 hours looking another topic
drag 1-4 quartermile 0-400 et
heres mine form yesterday .never dragged aything before
run 1 2 3 4 5
reaction 0.415 0.637 0.281 0.521 0.673
60 ft 2.31 2.29 2.30 2.06 2.16
et 14.56 14.34 14.40 14.10 14.06
mph 96.95 97.10 97.34 96.68 96.89
fat f**kin wagon . itll go better when i get it tuned and a real clutch
https://www.sau.com.au/forums/topic/332999-stagea-drag-times/
Calder park, first time out. M35 Stagea with full tank and street trim. (I only took the baby seats out. :) )
Average reaction time 0.5 seconds
Average 60 foot 2.5 seconds
Best 1/4 time of 13.5 seconds at 171kph due to factory speed cut.
Vids:
I will have to go back now I have disabled the speed cut, hoping to crack into the 12's.
Ok back in feb @ Calder Park
Run
1. R/T:- .692 60Ft:- .000 1/4 Mile:- 16.697 MPH:-85.55 KM/H 137.69
2. R/T:- .620 60Ft:- 2.416 1/4 Mile:- 15.959 MPH:-85.51 KM/H 137.62
3. R/T:- .657 60Ft:- .000 1/4 Mile:- 15.747 MPH:-85.34 KM/H 137.35
4. R/T:- .599 60Ft:- .000 1/4 Mile:- 15.693 MPH:-85.97 KM/H 138.36
5. R/T:- .638 60Ft:- .000 1/4 Mile:- 16.066 MPH:-84.69 KM/H 136.29
6. R/T:- .683 60Ft:- 2.195 1/4 Mile:- 15.580 MPH:-85.93 KM/H 138.30
7. R/T:- .600 60Ft:- .000 1/4 Mile:- 15.531 MPH:-85.55 KM/H 137.69
8. R/T:- .686 60Ft:- 2.168 1/4 Mile:- 15.428 MPH:-87.69 KM/H 141.12
9. R/T:- .712 60Ft:- .000 1/4 Mile:- 15.412 MPH:-87.81 KM/H 141.32
10. R/T:- .658 60Ft:- .000 1/4 Mile:- 15.232 MPH:-88.85 KM/H 142.99
the .000 60 Ft time was because the right markers were not working
pretty happy with this.. once i have some cash on my side i will bemaking mods but untill then.. :)
Fastest was the last run of the night.
and run 5 wass because i forgot to turn the air con off for that run.. :D
Calder park, first time out. M35 Stagea with full tank and street trim. (I only took the baby seats out. :D )
Vids:
Watched your vids, this thing really does get a shift on! Can't wait for higher terminal speed!
Pfft, Commodores, probably thinking "Shit, what kind of V8 does he have in that Volvo, I need more NOS!"
  • 2 months later...
11.33 @ 124mph on street tyres and full weight (1740kg + driver roughly)
Im tempted to test out the new setup (26/30 and 3076r turbo) but clutch doesnt like the power at moment, so until i swap it i wont be seeing any drags, plus i got a bigger turbo (gt35 1.06 twin scroll t4 flange) to go on too if i can be bothered swapping it over.
Well after a hot arvo of 32deg at Willowbank Raceway, I did got 5-6 runs and the clutch started to over heat
Parked it to cool down so I could make the 80-90km trip home.
Run number 3 was the best.
328rwhp
Run1
60ft 2.250
1/4 13.853
mph 101.01
k/mh 162.55
Run 2
60ft 1.960
1/4 13.681
mph 100.76
k/mh 162.15
Run 3
60ft 1.981
1/4 13.545
mph 101.83
k/mh 163.88
Run 4
60ft 2.386
1/4 14.3
mph 99.46
k/mh 160.08
Run 5
60ft 2.158
1/4 13.648
mph 102.66
k/mh 165.21
Edited by darrinspencer
nice work darrin, how does the GT30 go launching the stagea off the line? are you still running on the tune you got back in May/June?
Same tune, hence the 328hp, not the 400rwhp it is capable off.
The launch is had to get right. the weight of the car, with AWD grip puts alot of load on the clutch as I found out.
Not enough revs and it bogs down, too much stinks like hell.
Had to slip it off the line at around 3-3500 rpm.
What kind of clutch do you have ...single plate??
Yeah single organic sprung centre, suppose to be good for 300rwkw. Pretty to drive on the street, esp since I do 80km a day going to work
It is built by Race Clutch (Jim Berry) very well regarded in OZ
Will have to find a streetable twin plate maybe
Have an Rb30 in the planning.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
