  • Replies 467
I just make a cut in them with tin snips, then use some vice grips to tear them off, kind of "rolling" the grips to help tear the metal if you get what i mean?
They're just an interference press fit onto the hub, no need for major surgery to get them off, just bend/tear/snap them off :banana:
It can be fun getting them off - lots of twisting rolling and yanking with vise grips and bull nose pliers. I also used a hammer and chisel to clean up the last remnants off the back of the hub.
Look at the little bastard cowering in the background after I got all tony danza on its ass
i only remove the front stone guards, or else they would be hitting my disc :S
anyway received my pfc d-jetro in the mail today :D however im unsure if the sensors send with it are the map ones (as they look nothing like the normal ones i have seen other on the net)
thanks :D i wasn't sure as they look very similar to the apexi boost gauge senders i had.
now just need to work out how to install them and off for a tune
Yeah electronic boost guages use a map sensor as well hence why they look the same - same thing with boost controllers (avc-r etc).
You just need to hook them up off a good vacuum / boost source off the intake manifold. It would be a bit different with the rb26 having individual throttle bodies - I have only ever installed map based ecu's on single throttle body systems. You would want the vacuum / boost seen after the throttle bodies.
Speak to someone who has installed d-jetro for sure!!
Thanks did some looking looks like you need to tap some fitting onto cylinder 3 and 4 in the plenum.
So now just need to wait till i get my hks afmless pipe and blitz ebc (id3) and see it off toget a tune. Atm i increase boost to 1bar (bleed valve) and the cars feels alot better still laggy but pulls harder might just keep the n1 turbos for the moment and see what sort of times i xan get at the track
does anyone know how to determine the spring rate of a spring?
i have just purchase a set of coilovers to start off with, however they have had their springs swap for some swifts springs and the owner doesn't know the rate
Usually it is marked on the spring somewhere.
Bloody easy since most of the steels used to produce these springs have very similar properties.
Try this calculator:
http://www.racingsuspensionproducts.com/spring%20rate.htm
thanks :geek: im hoping the spring rates aren't too crazy!
btw could someone explain to me what the helper springs do? (extra spring at the top of the normal spring)
thanks :) im hoping the spring rates aren't too crazy!
You want crazy spring rates, the car will handle better that way
:P
Keeping the main spring captive under full droop is all they are there for.
The purpose of them varies depending on if they are helper springs or tender springs.
I'd assume being japanese they are probably only going to be a helper spring.
Article about Helper Springs vs Tender Springs
Sorry my mistake they come with Assist Springs
Just because i wish to run 10/10 doesn't make them crazy spring rates, what i am worry about is that the spring rates will be in the 15 region as its not uncommon to run such rates in japan.
I understand that the general thinking is that 10/10 will be too stiff. However i have good experience with those spring rates in my r33 track car and will be testing similar rates out in the gtr. I plan to start with 6/8 combo however i need to do some reading on this Assist spring and select the correct rate for that combo. If 8/6 doesn't work i will move to 8/10 etc etc
till i find the right setup for my gtr
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
