Hey guys...
I am under the impression that R32 GTS-t runs a T28?
If so, would a T3 be a straight bolt on?
If so, how much boost can a T3 safely run?...
How much am I looking at for a T3?
How much for the conversion? Any other parts i need to plan for straight up?
Are there people on this forum that can help me do the conversion ourselves (safely and for a small fee ofcourse)...?
If none of the above can someone fill me in?
Thanks heaps...
Dave.
https://www.sau.com.au/forums/topic/33365-t3-turbo/
  • Replies 48
Dont go looking to get a turbo to run a certain boost figure, look for a turbo that supports the sort of cfm/power you are after.
Simply running 19ps doesnt equate to a quick car, with the wrong turbo it could easily equate to high inlet temps and a cooked engine.
So perhaps a better way of going about it is deciding the power you are after, and then what turbo best suits that level using the lowest possible boost, whilst still providing good response.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669327
I run 14 psi and its a 12 second car. 19psi means nothing. Its the flow and effeciency that counts.
The turbo from a R33 is not a T28
but its niether a T3, yet its a T3 bolt pattern!
confusing? it gets better, Nissan bought about 5 different series of these turbochargers, from garrett, but they are all ceramic, and Ball bearing (even the GTR ones) and all the R33 ones can have on the cover, 45v1, 45v2, or 45v3 or 45v4, and I have ever heard of 45v5. What that means? Dunno...
So the best way to refer to these turbos (by the way they are the biggest factory nissan turbo you can get, and pretty damn good performance too) is "a RB25DET turbo"....theres simply no better way to avoid problems.
I went to get a turbo from someone once and found myself looking at a T28 from a S14. I wasnt impressed heheh:P
My car is a VL with a RB25det with two of these turbos on custom manifolds. Boost hits like a mac truck at 3800rpm and gives awesome power delievery. I run 1 bar boost (approx, its actually set atm on 1.05kg/cm) and there is no problems with the ceramic wheels.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669754
R32 has a t3 turbo (fast spool up)
r33 has a t25 turbo (slow spool up)
s13, s14, and s15 has a t28 turbo (go up to 1.1 bar on a stock silvia.
You can use a t28 (uses a t3 flange). you have to get a differant outlet and mod the inlet, also add tap on the outlet to the intercooler. cheep upgrade.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669761
Hi stimps, well said, boost is irrelevant, air flow makes power, boost is a measurement of restriction to airflow. So more boost can mean that the engine is inefficient, not that it makes more power.
Only one correction on the Nissan turbos, Nissan owned the tooling and Garret made the turbos. But around R34 time Nissan tendered their turbo supply out for turbos to be made using the Nissan owned tooling. Hitachi won the tender, so the later turbos are actually made by Hitachi using Nissan tooling originally made for Nissan by Garrett.
Confusing, huh?
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669849
Try here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=30556
I bolted up a T3 to my 33's stock exhaust manifold etc. It's not quite a bolt-in affair, but it's about as close as you're going to get without buying a 'kit' for your car.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670200
Yeah I know you said 32, but the only step-by-step I have is for my R33, so that's what you get :P
I thought the RB20 exhaust manifold was the same as the RB25 one? The turbo and space to the strut tower etc is no doubt different but similar rules should apply.
You should be able to run 12s with the stocker if it's well tuned. 4Doorz on here has a FMIC and home-tuned PFC on his 33 and he broke into the 12s, I image with less torque but also less weight with a 32 you could do something similar. That said, a bigger turbo will make it far more easy :)
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670636
Yeah... and the turbo's getting old too.... although i know it's still running perfect, it can't hurt to upgrade to a new one when i save some funds....
SO how much would i be looking at for a T04? then how much to install?...
who should i talk to? ADVAN?
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670679
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
