Have you ever taken it to the drags 1/4 mile time would be interesting .
Your high compression turbo set really interests me . My rb30 has an r33 rb25de head , using the rb25de pistons gives me 10.5 compression . a boost of 5 psi would equel a 7 psi boost at 10.0 compression . I,m part the way there in that i,m allready using rb25det injectors and have bosch 040 fuel pump , and i,ve got a rb25det exhaust manifold sitting under the workbench . So really i just need a turbo , oil and water lines and intake and exhaust pipes . Currently i,m using a 68 mm xf falcon t/b , and the afm is the same they use on stock rb25det .
I still have to sort out a fuel starvation prob i had when running at lake gairdner speed trials , need bigger fuel lines and maybe a swirl pot . I,m also using the stock rb25de ecu with an safc 2 .
Funny you should mention the starvation, would have though that setup would be fine...even for a turbo???
No 1/4 mile times yet...even though the others guys are calling me weak for not taking it down to Willowbank :D
We'll have to talk RB30's soon, I'm looking at building an RB30DET Neo, so you may be able to give me some guidance!
Hello Skylines Australia. I have an interesting subject i would like to chat about.
My project is to produce as much power out of the RB20 engine with the least amount of effort, meaning i want it to breath easily.
I have a couple of things i want keep constant though, for now at least.
8000RPM rev limit
standard crank rods and pistons
Aftermarket exhaust manifold
Modified stock intake
I would like the torque curve to start its climb upwards at right on 4800RPM. At least be well on it's way upwards. Before this speed I'm not interested in making grunt.
This engine has an Autronic SMC ECU attached to it, is a 3 speed automatic with a trans brake - Drag use only.
Their is also another important thing about it, it's a normally aspirated engine that i wish to run boost in.
Sounds impossible??? I think not
I have plans to upgrade the bottom end and the head, but for the moment all I want to do is run this settup with the propper turbo, injectors, intercooler and things like this.
I do have a goal of 450-500BHP, so i need to know from you guys what sort of turbo I'd need to run that sort of power. But if I get responses of numbers of models of turbos I'm lost, I have very little knowledge of what a gt30/gt40 has to offer in the way of airflow capacity under boost.
I'm looking for something different, the right combination of parts to run low boost levels but with massive AIRFLOW in mind.
Like an RB20 that kicks a 25's butt.
I'm sure somebody would like to see that
Thanks guys
Turbine.
hi turbine,
you should look at doing an rb30 bottom end conversion. if you do use the stock rb20 block it will be ok youll have to tuffen it up a little and the gt30 on rb20 will be laggy as all hell, forget gt40 its way too big. check out threads in forced induction titled "top rb20 260rwkw club" see what configs they are running and check out the rb30 bottom end thread as well. can be done for about $5k but then you need turbo and other associated stuff with it so 10k at least. the 25t has more torque, better turbo and better airflow. does the smc communicate with the auto box or is it a non auto based ecu?
Hello paulr33
The SMC is a standalone ECU, almost the altimate engine management system.
I'm not realy interested in the RB30 bottom end just yet. It's easy horsepower that way.
When you say about the gt40 turbo being laggy, thats good if it is laggy below 4800RPM because it's a drag car, I dont intend to have midrange power, I'm aiming for top end high revving horsepower. So will the gt40 be good at 5000RPM to 8000RPM?
yes i understand what the smc is, does it have support for auto or is it a manual only ecu? what happens during gearchanges? does it have logic for automatic gear changing or does it just keep the throttle nailed. the gt40 is on the xr6turbos 4 litre so it should be mega laggy on an rb20
you should find out how your ecu handles the autobox cos at the power rating it will fry the gearbox and give it all kinds of hell. if your stuck with smc and it doesnt support the auto (as in has no logic for gearchanges) then change to a mechnical autobox. only electronic autoboxes will get fried and a mechanical one is fine
Gearbox is good for 450kw engine (reliably), has a transbrake and high-stall converter, full manual operation.
If you are just interested in drag racing, their is no need for gearbox logic really, just do trial runs at different RPM's and watch what happens to th E.T and MPH.
Circuit cars, well thats a different ball game.
Okay just a thought but why wouldnt it be better getting a Engine Implant or just saving up for a GTS-T or a GTR. . . I mean doing it your self i just dont think you would be worth all the trouble. Look i know you may be cheaper to convert the skyline yourself but i dont know the timeline comes into. My mate got his Skyline GTS converted and it took him over 6 months to finally do everything. . . thatz souceing parts. . getting them installed. . tuning. . . geting conversion correct. . . and itz not a simple wack it on and it will go. . .itz alot tougher than most people think. . .
Ok, search forum was a no go for info. so.....i'll try here. :(
Can all the turbo bits from an RB20DET simply bolt onto the RB25DE? I found a great donor car and want to try it if it'll work. I don't plan on using more then the stock boost (or just slightly more) and only want to touch the 230-40HP range. More is nice, but if not then as close I can get will do.
interesting thread 666dan still waiting for a power figure from your car?
I have a cefiro with an rb 25 defrom and r32 I will be considering the turbo route over the next 12 months. jsut deciding if I want it or not.
from memory crooser had this set up for 2 years or so then pulled the otor and checked it and the was no additional wear.
meggala
Yeah gatty that's a better idea, that's the way all of the GReddy bolt-on kits work....forgot to mention it!
If you do a search you'll easily be able to find installation instructions for the RX-8 or 350Z kit, go by what they do.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
