Hey everyone, just last week I came up to an oportunity and I couldn't resist
So I bought a 1998 r33 gtr :)
Mods
Catback exhaust 3.5inch( need custom dumps for new turbo)
Hks pods
Power fc not installed
I got it pretty cheap so I didn't check it much as long as the bodys straight witch it is because looking to rebuild in the near future,
As being a rb25 boy for 4 years not sure how much the rb26 can take and what would be a good setup.
Any way I took off the front bar , front mount etc to find out heaps and heaps of blow by and stops just after the bovs . So turbo oil seals are gone skies.
So I've got around 5-6 k to spend and buy some goodies :)
Already have power fc with hand controller
I want to keep the twin setup and don't want anything monstrous that will kill my motor or anything.
Hopefully I can reach round the 300kw mark :)
What would the best set up be for my budget?
Some one point me in the right direction !!!
https://www.sau.com.au/forums/topic/334414-just-bought-a-gtr/
Lots of oil around doesnt mean much TBH. Could simply just be normal blowby, car is 10years old etc, so buildup wouldnt surprise me.
Suspension, full oil changes (diff, transfer case, gearbox etc) service, brakes, PowerFC tune etc IMO.
All belts and the like is where you should spend the money IMO.
Otherwise...
Turbos will be 2500-3000
AFM - 650
Injectors - 800
Labour - 1000
clutch - 1500
So already blown your budget and you still have a car:
1. doesnt handle as well
2. isn't fully reliable by any means of the word.
All of a sudden you've spend near 10k when stuff starts letting go.
Get it all in good condition first, then chase the power.
yeah bro, defiantely start with a nice clean up of the shit first and a catch can. get the pfc in and c where u are from there.
i dont think 300 kw is a good target really in terms of the money u would be spending id be going more for the 380ish mark if u only wanted 300 u should have kept what eva rb25 powered car u had before
As everyone said, if you're not looking at spending huge amount of money, stick with 300awkw as a target. Even that will cost.
The next GTR I get will definitely be one thats got work done or one that is similiar to the N1 (maybe a NUR? hahaha). Cost breakdown as per below (all brand new parts);
1) Catback Exhaust = $1400
2) Dump Pipes = $500 (probably dont have to change if you've got a 34GTR but normally 32/33 will change them when doing turbos)
3) Turbo = $3000
4) ECU = $1400
5) Oil Cooler = $500
6) Clutch = $2500 (I would only like a Nismo Super Coppermix Twin personally but could be way cheaper if you go exedy or npc)
7) Boost Controller = $600
8) Tuning + Installation of ECU/Boost Controller = $1000
9) Metal Hi-Flow Cat = $350
10) Adjustable Coilovers = $1500
11) Labour = $2000
Thats almost $15,000 worth of mods and I would consider these to be basic essential GTR mods for you to enjoy the car's potential. By this time, your car would be very realiable at anywhere between 250awkw-300awkw (depending on your tune etc). If you want dead set 300awkw or slightly above, you'll need fuel system upgrade too and below are some extra cost.
12) Injectors = $1000
13) Fuel Pump = $350
14) Assuming you do not have AFM or else another, AFM = 700
Bare in mind, these will not be the end if you bought a dead stock GTR because you will want to change the rims, brake pads, rotors etc at some stage and the cost just keeps going up. Thats assuming the engine is still running good.
Upgrading the oil pump would be preferred but its a BIG job so not a lot of people would do it. Also if you're doing major service, maybe chuck in the N1 water pump because they've got lesser blades.
Just got it devices with royal pulple 10w-40 k and n oil filter new fuel filter cleaned out all the oily shut in the intake , took the intake manifold off cleaned everything :) I got a cusco catch can not sure how to hook it up my mechanic said don't use that one but I don't see why not? Just the silver one with the blue fitings but hasn't got a breather in it.. Do I need one ?
And another thing the bovs seem fine but it's doesing like a mutherf**ka I Gota look turbo side and see if the recirculating pipe are blocked...
Cheers for all the adivce guys I'll let you know what happins after the tune :P
Keep the discussion going!
i dunno much about the gtrs mate but with the catch can
you want to run the line that goes back to the intake into one side of your catch can then run the other to the intake
so the blow by goes through the catch can on the way to the intake
you can put some steel wool in there too to catch the vapour too (make sure no small bits are gonna come off tho
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
