I bought the matic-J oil the other day was gonna do it myself today.. from the info i have found dropping the oil out the drain plug will only remove half then i can just top back up the exact amount i removed.
Or should i take it to a mech and get them to flush and fill with full amount??
im only asking coz i found mixed results, some saying not good to flush the system(unwanted pressure..etc) and others saying not good to just drain as your not removing all the old stuff..
I just want to know what others have done.
either way im happy to do myself, or take to mech as i have bought the expensive stuff.... matic-J is like the cost of liquid gold. :ermm::)
thanks
sorry to start new thread.. but the M35 info one is getting massive and without categories gets hard to find stuff..
https://www.sau.com.au/forums/topic/334650-m35-transmission-fluid-change/
This is for S1 but pretty sure M35 is the same (i.e. the sump will hold a lot less than half). You could do it without dropping the sump. This way you are just using the stock auto's pump (it has been suggested that the pwer flushing system of the auto shops can damage seals but I can't verify that):
Get yourself an auto sump gasket kit and a 20L drum of (ideally) quality synthetic atf. You need 12 to 14L for the auto and you can use the rest for your attessa and power steering. Drain the sump and drop it (easier said then done - you will have to support the box and remove the rear mounting). You will only get betweeen 1 and 2 litres this way. Check that the new internal filter is exactly the same (otherwise the sump won't go back on) and if not either modify the new one to suit or clean the old one and put it back. Put 2L of fresh oil down the dip stick tube.
Then pull a hose off the trans oil cooler and run the engine until you have pumped out 2L into a container. Pour 2L of new oil down the dipstick tube and repeat until you get clean oil coming out. This will take 12 to 14L in total.
You should be able to get quite a lot by draining (about 4L or so), unfortunately ours takes over 8L, so you could do it again the following weekend which is effectively just diluting the old oil with fresh stuff or alternatively take it to Nissan for a transmission flush and take the price of the oil off the bill (you will lose $$ though).
hmmm.... while I think about it, would something like the Liquivac work for removing all the transmission oil?
matic-J is like the cost of liquid gold. :D:(
Maybe look at getting some Matic-S from the US? We have yet to receive it in Australia, but it is the 100% synthetic replacement to Matic-J.
Agreed.....
couldnt agree more with another forum for m35 stuff.
I keep confusing peoples comments about S1's and S2's until i notice either C34 in their list of cars or their avatar of a c34.. and im like meh doesnt apply to my s1!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
