  • Replies 313
Posted Images
smartass :(
if i remove my arm that sticks out ill have no arms - would just look weird then
so id possibly have to add arms - or maybe it looks like my arms were crossed
and I'm just not that good at PS
and frankly i don't think the pic is SOO amazing that its worth spending hours in PS for it lol
Well a totally different lighting.. Dark, edgy, arty type look:
ssshh be quite!!!
Love those shots and the model, Sidd. Did you use a snoot to "channel" the light around her like that?
Thanks ;)
No snoot, but rather the use of different grids. So you have your reflector (what ever size it may be, and a grid to suit it). Hope that helps??
Once i get home tonight i will post a behind the scene shot for you.
Edited by siddr20
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
