What physical driving characteristics would be noticed( or other aspects) between
the VQ25DET engine and Neo VQ25DET engine in a M35 Stagea 2002
"a NEO engine is classified as a low emission vehicle (LEV) engine due to their
lower fuel consumption and emission output. The NEO head featured solid lifters
rather than hydraulic, revised camshafts and a revised inlet manifold, in particular
the RB25DE NEO which had 2 inlets going into the inlet manifold. The combustion
chamber of the head is smaller, so GT-R spec connecting rods are used to compensate.
The turbo received the larger OP6 turbine."
Is there a NEO VQ25DET available ??
Scott, you really are naughty speaking so derogatorily of your ancestors.
BTW the H20 was used in TCM Forklifts.
Looks like I asked the wrong question.I guess thats why we have forums .
Whats the difference between a motor being a Neo and Non Neo motor
Edited by samuri
actually SRs sound like trucks. especially when they have VTC rattle.
anyway, the neo vvl is variable cam timing, duration and lift unlike the VTC equipped engines that were only variable cam timing.
The older neo engines just switch on a set degree on the intake at certain revs.
Ours can run anywhere between, constantly variable, but you can only adjust it with the Vmanage or a remap. Hopefully one day...
CVTC makes the engine a bit smoother, neo rb's have a dip in power as the cam switches in looking at the graphs.
neo rb's have cvtc
its the r33 rb25's that have the on/off vct
Ah right, so ours may use a very similar system, I was hoping to get a Vmanage some day to allow me to adjust the cams in limp mode. :( Then I can install the cable throttle again...
doesnt the emanage ultimate have nissan VTC output??
i remember my emanage blue had one for my SR20. mind you it made sweet FA difference if i changed the cams to come on earlier. turns out the factory setting was perfect for that engine!
Yep, it has a switch output (for Vtec etc?) but cant control the cvtc without the Vmanage.
Scotty , is that an aftermarket aerofoil of sorts on the rear roof area of your car,and if so where did you get it?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
