yeah, just wondering what people use in their radiator, some some water is fine some say not some use additives like water wetter.
I just flushed it with a hose and filled it with water and a bottle of corrosion inhibitor
Do radiator flush additives work?
Is coolant really necessary?
What do you reccomend?
What works?
https://www.sau.com.au/forums/topic/335673-what-do-you-put-in-your-radiator/
Yes I would use coolant or your water pump won't be too fantastic down the track and that water will turn brown :D
Water is for topping up or adding to coolant concentrate mixes. I'd only use it if I had no choice.
Rust and scale removers work alright when flushing.
Yeah i read something about coolant lubricating the pump, I usually use it but didnt realize i'd run out.
But i also read another guy says hes used nothing but water and redline water wetter for 10 years with no problems..
So just wondering what i should get to add to it
Edited by Arthur T3
definatly flush the system and use coolant, i use nulon long life coolant pre mixed $20 for 5 litres so you need 2... or u could by the concentrate and mix it yourself with demineralised water. tap water for flushing only....
in my old corolla pre 80s i use the corrosion inhibitor and water wasnt really designed to run coolant...
Yea one of the reasons you are suppost to use coolent is because it has a higher boiling point than water. The water will evaporate through the overflow bottle after long drives. I use rust repellant coolant, however if you have a corroded cooling system just buy the radiator flush and do it yourself shouldn't take long.
I only use straight water to flush the system. Once it's flushed I just pour in pre-mixed Nulon red along with 500ml of Motul Mo'Cool. Works fine for me and has kept the temps consistently lower during the hotter months.
Yeah i ran a bottle of flush through it for over half an hour, not sure if it made a difference, the water that came out was brown but so was the the flush mix i put in it.. :P
Another guy told me he just runs the engine with the hose stuck in the radiator.
I also read somewhere that plain water actually cools better.
But i do remember the old man topping up the radiator in the his HJ monaro all the time, He had to check it daily. I have never had to with coolant so i guess there is truth to what you say mr massive..I didnt know this b4..
orange juice
never use tap water ever this is the worse thing u could do... oh l lie u could do worse: bleach, drain cleaner, fuel, fluorine gas, OJ.
the only water you should use is distilled water most good auto shops stock it in +10L bottles or just use the pre mix
flush with the tap - put the screw back in - fill it up with tap water + some radiator flush - turn engine on with radiator cap off - idle for a few mins - drain / flush with tap water - fill up with coolant + top up with distilled water.. has never failed me. (someone correct me if im wrong)
^^ yeah thats what i did..
Someone told me to fill the radiator with coca cola and then throw a packet of mentos in it. Apparently the reaction is really good for cleaning out the corrosion..
Has anyone tried this??
That someone has been watching "Mythbusters" too much. Diet Coke + Mentos = BANG.
That someone ought to be shot!
Wanna shotgun??? MORE BANG!!!
back in the day some mechanics i know used to use coca cola to flush radiators and even clean the oil stains off the floors. however doing that with the coke sold today and all you will end up with is a sticky mess. as with most things these days, they aren't as potent as they used to be.
....I also read somewhere that plain water actually cools better.....
absolutely right, water is about the best thing in the universe for taking energy and getting hot slowly. only 2 problems - stopping rust (corrosion inhibitor) and it freezes at 0.....
When I was having cooling problems I ran straight distilled water + redline water wetter, it ran literally 10-15o cooler than coolant.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
