There is something not quite right about the look. its the width or something, can't quite put my hand on it. But I think it looks great.
Question is, spend 15k on that and have a stock motor? Or keep the normal nose and drop 15k into the engine? I think i know what i'd rather... :D
I think it looks good. The rear arches need to have the same styling though(somehow) and needs bigger/ lower side skirts and a rear bar. Other then that, looks great and would be super different, so i would still have it in a flash.
I've tried pricing it all up, Nissan over here wouldn't give out prices for GTR parts.
But I imagine it's not cheap, an M35 bumper is $4,300 + gst here.
Check out Japn yahoo for second hand. Parts are cheaper than R34 gtr's. Easy to get front end bits due to people upgrading to carbon bonnets and fancy front bars.
Front bar approx $200
Bonnet $300-400
Have seen head lights on SAU for $1200-1500 each
My R34 front cost me $4500 in s/hand parts alone.
Reckon you could get it all done for 15k?
I dunno aye... I reckon the headlights will cost around 5K each :)
Considering our headlights are around 2.5K each haha
Thats what the guy says so in the other forum.
"You can pick up an M35 Stagea for around 5k upwards. If you could source second hand parts, which are rare, I reckon that would be around 2-3k So with the car, parts and labour, I reckon you'd be into 10k+"
Of course your talking GBP, not AUD. I guess it comes down to how handy you are with a spanner + Welder eh? 2nd hand parts would be the only way to go. Lets not forget, the guy owns a R35 anyway, so he mustn't be short of coin!
just been on the phone to this guy just thinking of get the back done as i have the impul front to get the back with the R35 tall pipe,s around 700 UK pounds , so thats my next step
hmm.... interesting! Would be interested to see the exhaust he has in there (and how loud it is) and how he got around the ATTESSA pump
wow, way to make your stagea look like a bag of dicks.
front's wider than the rear. the fender and the A pillar doesn't line up properly. the front bumper doesn't line up with the bonnet. man if you're gonna do something unique, do it right.
like wilson tuckey says... do it once, do it right and do it with fibre.
Farken lol. Always good to get a colourful response from you shan. I bet Neil is missing his stag.
Totally agree, doesnt line up at all and needs to to be wider. Some others I have seen look better.
Edited by dirtyRS4
Me too, not sure about the styling issues. Also I'd question why you'd bother, especially in Britain where cars are cheap. For that money you'd get a 2001 Maserati. For just under 20K (pounds) you can just get into a V12 Aston Martin Vantage.... or for less than the 10K take your pick of M3's, Audi Rs's etc.
There's a limit to being different I reckon. I play with my cars but if those sort of cars were that cheap here, I'd be getting one of them rather than a bodged up half breed.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
