  • Replies 44
well i dont know what im downloading but im downloading something off those 2 links?
what was that thing that cobra guy was trying to complile in visual basic?
Fluz.. i have the r32 manual downloaded.. so if you want I could burn it onto a cd for you next time I see you. :rofl:
