um yeah was just wondering if I can rock up this time without paying for the (AASA?) licence because I paid for it the last time but haven't actually received anything?? Was told it'd arrive in the mail (not sure how when you don't even have my address) so yeah...lookin forward to this
  • Replies 189
the asaa licence is a 12 month licence so you wont need to pay for it again.. you will have to contact either one of the execs or cams themselves to get a copy of the licence as they may not have had a addess to send it like u said. BTW your address should of been on the entry form
I entered as a N/A before the conversion..
see here:
you will have super throttle response and might end up being quicker than most of the turbo ppl
see how slow i am now!
p.s. START SENDING EMAILS OR FAX'S PPL!
You didn't mention to someone that you didn't give an address?
Best bet is to call AASA direct and tell them your address so they can send it. It's probably sitting on a desk somewhere ready to go
Just to confirm, AASA and CAMS are two different organisations. Either way, we accept both a CAMS licence or an AASA licence, and as AggroDave said, they're both usually valid for 12 months each.
wasn't going to do this one, not sure if my new car will be up to it but then I saw the courses. Can someone send me a PM about helping out? If you help out you can do a few runs at lunch right? That would be enough for me right now I think.
Yeah actually my address was on the competition entry form ... but I haven't received anything in the mail yet. Any chance someone can chase this up for me ? R34 with DR34PR rego plates on entry form.
The competition entry form, and the aaas form go to 2 different places. We just send away the aasa licence forms. You will have to contact aasa yourself unfortunately and chase them up.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
