hey all have a full nizmo aero kit to suit 34 2 door. is a genuine plastic factory fitted kit which came off my 34. pearl white in colour
includes front bumper
rear bumper
side skirts
argueably 1 of the best looking factory fitted kits for the 34 coupe
would prefer to sell this as a whole so someone can just go bang and put it all on. no searching for this bit or that bit separately. would be a shame to separate this complete kit. if unfortunatly no one wants to take as a whole i will separate as long as all parts get are are arranged to be sold
sory dont have pics atm i am sure you all know what this kit looks like
$1600
am more than happy to help with freight to anywhere at your expense
thanx guys any more info pm me or 0409446951
  • Replies 42
Posted Images
front bumper $550
rear bumper $550
skirts pair $500
organise amongst yourselves who wants what , as long as it all goes to a home will separate no probs guys:)
am in perth :thumbsup:
ok kit looks like this : http://www.skylinesaustralia.com/forums/R3...ts-t204546.html
Edited by rexrxr
front bumper $550
rear bumper $550
skirts pair $500
am in perth :D
ok kit looks like this pics!
'kay - just wanted to clarify - because what most people call the 'nismo aero' kit isnt - the pic I posted before *is* the nismo aero kit front-bar (very rare). Most people have the altia front bar and call it the 'nismo' one. Just thought it was worth clarifying.
ok sounds like like theres a few diffrent names people call this particular kit , could possibly be called a altia kit? front bumper has fairly big holes with skyline written in middle. hope this clarifies what exactly it is :D
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
