I make this public, I think this is probably the highest HP out of a high flowed R33 turbo ever archived with 98 fuel internally gated. This is our PU high flow option.
Once thanks to Trent at Status for excellent tuning work.
Fully stock RB25det engine with forged pistons only.
800cc injectors, Nistune ECU, FMIC, Exhaust and 3inch intake pipe.
Car peeked 305rwkws @ 21psi, full boost by 4200RPMs. The average run was 300rwkws.
Yellow line is straight off high pressure actuator, no boost controller. Green line is with boost controller.
stao took me for a spin with this turbo last night and in a restricted form too (with std airbox) and wow what a thrill when it hits. I want one!
Edited by Harey
What makes you say the airbox is causing a restrction?
Thanks for support guys. Details of this high flow through out development and manufacturing is in our high flow thread.
I took Jeff for a spin that night with air box lid on. Very noticeable difference in how car reacts to throttle compare to a POD. The car was dynoed with a POD and 3inch metal intake.
I got some video footage I will put up later on.
Might be valve springs, I'm not too sure. I did hear a light pop just before the rev limited kicks in. That little dip is always there. Any thoughts would be great.
that is in .82 rear. The difference with an Air box would be, well it sounds very differenct lol. It just doesn't pull as hard, and feels like I'm down in torque.
Is it running out of flow around 6500rpm and hence the nose over?
Or is that being caused by something else?
I dont know much but I dont understand why everyone worries about this so much, Its just a high flowed stocky and usually I'd be clutching by then anyway..
you wanna bounce of the rev limiter get a better turbo (and a better engine)............
This turbo has almost 150kw gain from 3500 to 4500rpm and for the street legal ,that is crazy and affordable power .....
Well done Stao :ermm:
Edited by Arthur T3
be interested to see a pod power pull followed by one with the stock airbox. i'm sure there is a point where the stock airbox becomes a restriction but it would have to be up around the area you're operating in.
great result!
congrats on the results mate, iv just purchased a 0.63 version of these turbos from another forum member. what can i be expecting from that?
Would you know the member's name and which forum it cam from? They all got different profiles in them refer to what the original customer wanted to do. Or you can pm me a photo of the comp wheel and turbine wheel I should be able to tell you what it is and what its capable of doing.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
