That is a massive turbo, if your going something that big you should either know what you are doing or be taking the advice of a GOOD mechanic.
No offense intended mate, but this sort of question is not one that needs to be asked... You are looking at a turbo capable of over 1000HP.. Which in turn will be a $xx000 engine setup. Note both numbers are missing, meaning I dare not assume it will be under 20 or even 30.
Just to put things into perspective, a 35R can run a 10. So the question is, what do you hope to do with a GT47?
Don't take on a setup like this unless you have $50,000 to spend. This $50k can be spent two ways:
1. Really good setup with all the correct parts and advice and you'll do 9's all day. You won't crack 8's because you need the chassis set up properly and the cost doubles
2. Buy all the cheap shit parts around to get it to work and spend $50k fixing your setup for every time it breaks
take a look at the mercury motorsport nitto, it has a GT47 on a built 2.7l RB26, can only imagine its a LOT more work to get it performing on a 25.
There is no reason why it wont go on a RB25, but for it to work effeciently is a whole different story
Edited by jangles
Yup thats what I was going to say, talk to mercury motorsport. I believe they use nos to reduce the lag, plus a fully designed setup with lots of experience in big power cars.
No reducing the lag on a GT4788. But if anyone would know about bolting a stupidly big turbo onto a RB trent would be the guy to talk too.
47 on a 25 .. goose.
my 26/30 will be running a gt42 and i reckon that a tad ovakill, couldnt imagine it with a 47 and an even smaller engine lol
Oh come come now - you can't really call him a goose given some of your recent posts! :whistling:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
