  • Replies 270
Hey Guys just a quick update,
we're running behind with it all. very sorry bout that but it is the silly season and hard to collaborate with my friend to get these done..
i am pushing my friend every moment i catch him, hes the ace fabricator who did the last lot so hes a vital part of the process...
Sorry bout the lack of updates too. dont often get on here anymore since i am at tafe full time till February
Hi Angus is it still time to join you guys? I want one as well please let me know.
Cheers,
Fabio
Hey Fabio yeah no problem! when they eventually get done we will have plenty!
i can make any promises when they will be done, but i hope to get them done over my tafe holidays. (xmas to 10th jan)
cheers and thanks to everyone for the patience!
Thanks Angus! Regarding the fitment is it going to be exactly the same? Has anyone here done a DIY job for this successfully?
Just worried that I go into all the trouble to pull the stock system apart and I have troubles fitting it without decent tools that I shop would have....
Mate my car hasn't even arrived from Japan I'm cool with your schedule.
Can you please confirm price?
Cheers,
Fabio
I have a pretty customer one installed. I had to change the studs in the turbo to make them shorter to clear. easiest way to get access to the dump to remove it and put it back up is to lower the transmission .. you dont need to lower it much :)... n when your doing it, make sure the car is cold.. maybe do it in the morning when you wake up one weekend.. otherwise you might snap a bolt taking one off :)
  • 1 month later...
im still intersted and the time factor is fine as i exceeded my chrissy budget, and am still yet to have my massive NYE in melbourne..:wacko: :wacko: :wacko: so i will be breaking the piggy bank to pay for this!!!!
keen on one of these dump pipes pm me how to go about geting one
sweet basically im after a nice tuned full exhaust as well as extractors but i want to keep the exhaust silencer that comes standard with my stagea , see police turn exhaust of lest reason for then to look
Fujitsubo Legalis R Cat back is a very VERY quiet exhaust. it has a silencer on it, so the bigger tips can be used. looks awsome too!
and speak to scott about making you up a dump-front pipe with a cat :thumbsup: an extremely quiet exhaust with maximum power benefits!
mine is realy quite what i ment was i have a factory switch in the cabin whitch alows me to turn the exhaust down so it makes nexrt to no sound then turn it up and its throaty
maybe a baffle in the rear muffler that can be adjusted not sure?
so i want to keep my nice big muffler and tip and just get a nice tuned exhaust from that forward so ill look around
Edited by Sidius
the fujitsubo has a joing where the last muffler is.
So did this dump fabrication die or something? Should I be shooting Scott a message after one?
you should be sending scott a message
i did. lol
lol... Kakimoto N1 Hyper Mega would be a very quiet exhaust compared to what is on your car bud!
Yeah, definitely let him know, but remember that he does this stuff around his job and family so don't expect it straight away.
+1....the Legalis R is pretty sweet. quiet as hell but opens up when you hit the throttle...
Not cheap though >_<
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
