Hey guys,
I'm just about to go in for a new tune with a few new parts about to be thrown on the car and decided it was probably about time I get a new computer before I do so...
Of course the Power FC is an obvious choice as it has been around for a long time and is backed by countless performances, but I've also been introduced to the microtech LT12S which I've been told is just as good if not better. Just wondering what are some positives/negatives between the two and which would suit my set up better?
I have a 96 S2 rb25det skyline that is all internally stock and just want it set up for street use but still of course the occasional drag and maybe circuit race aswell..???
Cheers
https://www.sau.com.au/forums/topic/337901-power-fc-v-microtech-lt12s/
i love anti-microtech threads like this.
I went against the 'norm' and bought a microtech ltx12s for my RB26, why..? because it was a bargain! (2nd hand)
For what i have it does a great job, i start the car hot or cold, doesn't stall out (as described by some), and honestly is driveable i've done 7,000kms using it, from driving to work to hard flogs on open roads.
It was easy for my tuner to get it all dialled in.
Power FC may be better - but for those with comments like "microtech sucks"... i just dont see what you base that on
The bmw takes 55L to fill, and i get about 420-450km of driving consistently, it makes 244rwkw.
If a car makes good top end power, has usable midrange, starts and stops when you tell it to, has local support... what more do I need?
Chris.
I actually have both computers and was trying to work out which one to use in my new build!.
I love my PFC, the hand controller is so much better to use than the useless one you can get for the Microtech also I have had dealings with two cars with these computers and neither Microtech's start properly, they cough and splutter for the first minute or so before finally finally running after a quick rev (that's if they don't stall first!). Apart from that they also seem fine. I have to say also the piggy back module looks dodgy, and mounting these things with it connected is a complete pain in the ass.
+1 for PFC i think (only downsize to this computer i think is having to use an AFM).
I would use one before a haltech E6X - E11.
:blink:
I'd use a haltech before either of the OP's options.
Power FC's are decent but as far as japanese ecu's go the F Con V Pro's are a much better option. (Limited tuners available in australia though)
There is plenty of good ecu's available in australia now though and as everyone else has said I'd find the tuner that you want to do your car and ask them what they recommend for the application.
Power FC only being able to store one map at a time and not having aux outputs was a dealbreaker for me.
Chris.
I had a Microtech LT12S in my car for a few years. At the beginning it did its job and I was pretty happy, it wasn't until time passed that it started really pissing me off.
Here are a few things that really annoyed me off the top of my head with the worst ones first. I'm sure there are plenty more things.
- No live tuning and no ability to save maps on a PC. Always had to have the laptop connected in the car and the car running to do any changes to the current map. This is because the map is saved on the ECU itself and can not be saved externally. With my Vipec I can adjust a whole tune while lying in bed and save multiple files of different maps. Then simply go to the car and load up any map I want.
- Can't reset ECU. Say some one completely f**ks with your map and you need to reset it to the base map. Oh sorry, you can't, you have to send it back to Microtech and pay them to do it. Or say some one only changes a couple of things and you need to go back to the way it was. You can't, you have to find what was changed and change it back.
- Bullshit fuel consumption.
- No knock sensor input.
- Smoke screen out the rear of my exhaust every time I went WOT. Now I have been told this is a Microtech thing, something about the injectors opening completely for a split second when you go WOT and you can't really tune it out. Not sure how true this is, but after speaking to a lot of people they all had the same problem and couldn't get rid of it.
- No ability to update firmware. Meaning what you buy is what you get. The Vipec constantly has new things added to it and its a simple free download to get new updates.
- Serial cable with that gay dongle thing that you have to pay more for instead of a damn USB cable.
- Computer software and hand controller is so hard to use and makes it seem like you are using something from the 80s. The Vipec in comparison is so nice and easy to use it's almost too easy.
Hmmmm what else....Oh yeah.
- Can't run external MAP sensors. Internal one must be upgraded by sending it back to Microtech.
- To set up Antilag you have to lose your aircon tuning adjustments.
- Got told you can't run a narrowband on one. Not sure how true that was, I tried playing around with that for a bit and couldn't find how to do it.
- Next to no outputs for setting stuff up.
And all that aint even really from a tuners perspective, I tried learning how to tune with it but it was way to difficult to learn yourself. The Vipec I picked up so quickly and the quicktune is just a godsend. That's all I can think of at the moment, i'm sure there were heaps of other things.
Edited by PM-R33
Chris.
TBH you dont know what your missing until you fit another more capable ecu... i personally love tuning microtechs cause they are so basic and simple even a kid can tune them only drama is they are coarse.
So true. It's like been fed SAO biscuits your whole life and then some one giving you a steak lol.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
