Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
Ah ok, was just thinking that because parts like CF bonnets weren't legal these might not be. But then these aren't exactly doing much in a crash :) all good!
As soon as 10 people are gathered PSI parts will start manufacturing them as that is the minimum required. So there kind of isn't a date as such....is that cool?
If not I can put a date up, but we only need two people anyway so it would be a safe bet it would be filled this week.
I understand there but there needs to be a 3 month cutoff date for even a EOI - otherwise a EOI could run for 6 months.
Ok no worries man.
Cut off date to get the 10 people needed will be until next Friday the 8th October. If another person aint found by then I will put my name down for two so we can get these manufactured :down:
Edited by PM-R33
Rigteo, need two more people then. Guys ask some of your friends or something, surely out of the millions of Skylines in Aus there are two more people that would want these. Don't make me have to buy three lol.
Edited by PM-R33
ill chip in for the other one, we'll just leave em available for 2 others when they come along
Yeah righteo. I'll let send Shane a message saying we have 10 ready for purchase :)
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2
8. MSTRSHENANIGANS
9. PMR33 (Extra set)
10. NA BEAST (Extra set)
GROUP BUY IS A GO!
I have spoken to Shane from PSI parts and they are sending the covers to get the moulds created since we have 10 kits on order :rofl:
So here we go.
The carbon surrounds have been added onto PSI Parts' website as can be seen here:
http://www.psiparts.com.au/detail.htm?ProductID=R33S-FOGL-CF
You will notice that they are at a RRP of $199 + $20 freight = $219. However our price is $119 + $11 freight = $130. This means a saving for us of $89 due to the initial group buy.
To receive this saving, a coupon must be used: R33FOGSAU
Here is a link showing how to use the coupon:
http://www.psiparts.com.au/faq-coupon.htm
And here is a link showing how to shop on PSI Parts' website:
http://www.psiparts.com.au/faq-additem.htm
So if everbody could start paying for them ASAP, the sooner we can all get them :D
If you have any questions feel free to forward them to me or to Shane at PSI Parts.
(Remember, more people can still join the group buy, just put your name down)
Thanks guys :(
Phil
Edited by PM-R33
I went to order it but when i enter the coupon code it says "Coupon Expires"
I have fixed the error, please try again.
Thanks,
Shane
I'm going to assume the coupon will work until the first batch has been made (as in this initial group buy) and is ready to ship out. Similar thing to the carbon cooling panel. You interested in a set?
I will make payment from next weeks pay :P
Edited by PM-R33
So is there actually an expiry date for the coupon or is it there all the time?
The coupon is only valid for the first batch and I will make it expire on the 22/10/10, so that gives you until Friday fortnight to get your order in.
Thanks,
Shane
Yes please :(
So you willl take NA Beasts extra kit and the next person that joins in will take my extra kit.
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT - Paid
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2 - Paid
8. MSTRSHENANIGANS
10. AAARGH 33
Edited by PM-R33
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
