Hi
I have been searching for a couple of hours, but don't seem to find anything like the problem I'm having....
Rb25det, 3" turbo back, Apexi filter, Freddy intake, otherwise original.
Doesn't matter hot or cold engine, it takes a few (2-3-4-5) tries to get it to start. This problem only started a couple of weeks ago, earlier it always started first try.
The strange thing is once it's running, it's all smooth, idle and rev, no noticeble problems at all.
Fuelpump is priming, diagnoses gave 55, no visual sparks around coilpacks (tested in total darkness), new temp sensor did nothing.
Plugs bcpr6es-11, fuelpump and fuelfilter is just a couple of months old (and not that many miles on them).
Any advise would be appreciated!
Thanx:-)
https://www.sau.com.au/forums/topic/338554-strange-starting-problems/
Cranking speed appears unchanged, by the sound of it it's all good.
Battery is less than a year old, measured 13.2V (14.1v at idle). Oh, and noise is just your normal noise, engine cranking. No coughing or sputtering.
Edited by 240zrb
No, I haven't got a fuel pressure gauge. But that could be a good point to check. I'll see if I can borrow a gauge.
Still, it pulls strong idle to redline (well, haven't tried redline but up to 5-6000). So, could it be fuel pressure..? pump is walbro, straight wire battery - relay - pump
  • 4 months later...
My gtr has started to do this recently too. After I put in bcpr7es spark plugs it would only do it when u go to restart the car when hot. Plenty of cranking then when it does start revs r very low so u tap the throttle and it picks up and idles perfect.
My cold start was perfect up until yesterday, now that's gone shit too
I thought it might of been those plugs so I put my old iridiums back in but same problem
Cars got sard fuel pump, nismo 600cc injectors, -7 turbos, and nistune...only been road tuned
Any ideas on what it could be??? Driving me nuts !
funny that u guys mention this as i have a similar problem with my r33 gtr.
sum days it starts perfect and other days it wont, have to crank it 2 or 3 times before it wants to start and have to hit the accelerator aswell to get revs up.
is there anyway it could be a starter motor or alternator related problem?
it gives me the shits, ill start it and drive to work then at the eend of the day it sum times doesnt want to start again.
i also changed the battery and that didnt help
I still haven't figured out this, but in my case I have discovered: If I just touch the gas pedal just a tiny tiny bit, and crank, it fires right up:-) So, I haven't tryed too hard finding the real solution to this problem. If I don't put pressure on the pedal it takes x tries to fire it up, and the same happens if I try to pump / half pedal / full pedal...
Thanx for the advice:-)
It idles at about 800 I think (hard to remember, haven't had it running for months)
I'll try checking the TPS, but not for a couple of months... I live in the northern most part of Norway, and it's freaking cold at the moment (well, now it's just -15 celsius, we've had a couple of weeks with -25-30 celsius. But I'm not firing the 25 untill it's + something.
And I need to hook up a diagnose plug, as it was not in the wiring I got with the engine. Engine vent into a 240z and I didn't think I would a plug, but now I need one for the Nistune:-)
Edited by 240zrb
It's just a summer car, as in only out on the streets during summer, but I'll keep your advice in mind:-) Thanx.
A pic if anyone wanna see the old Datsun with the new heart (and some plastic surgery...):
http://forums.hybridz.org/index.php/gallery/image/24342-73-240z-rb25det/
I know its normal for Norway, but I can't get over those -20' temps........I get a -4' frosty morning in winter and swear and curse and vow to move north to a warmer climate.
Well I guess you don't have to worry about +40' days at least.
And apologies for OT.
PS as DVS said your car looks tough :thumbsup:
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
